- To: St�phane Lescuyer <lescuyer AT lri.fr>
- Cc: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] List OrderedType as OrderedType?
- Date: Wed, 26 Nov 2008 15:07:35 -0500
Thanks. I'd started with a similar approach, but have stopped as I can use FSets for now. However, I noticed that you used a tactic that works for you but not me. I can't use the "subst" tactic, as it claims unification is impossible. However, I am reusing the "eq" name from the module instead of using "_eq" as you do. I changed the name to something other than "eq" and the tactic works. Why will "subst" fail to unify with a local "eq" but will unify with "_eq"? Is this a naming bug between local and FQ names in the tactic, or is it more fundamental?
Scott Doerrie
Stéphane Lescuyer wrote:
On Wed, Nov 26, 2008 at 5:38 PM, Pierre Letouzey
wrote:
On Tue, Nov 25, 2008 at 02:56:21PM -0500, M. Scott Doerrie wrote:
I've been searching the Coq standard library and have been unable toConcerning lists of OrderedType.t, FSetList.Make is building a
find a functor that creates an OrderedType given an FSet or even a List
of OrderedTypes. This seems relatively straightforward given the
implementation of PairOrderedType, so I've probably missed it. I'd
rather not duplicate effort, so I thought I'd ask first.
Scott Doerrie
FSetInterface.S whose base type is a sorted list attached with its
sortedness proof. As before, this FSetInterface.S can be seen as an
OrderedType. If you want to deal with arbitrary lists and not only the
sorted ones, nothing exists yet in the standard library, but it should
not be too difficult to build something (indeed, PairOrderedType can
be a good source of inspiration). If you write this kind of functor,
let me know, it might be interesting to include it in the standard
library.
I had actually written such a functor (see attached file) some time
ago, it builds an ordered type for lists with pointwise equality and
lexicographic order. [eq] and [lt] are defined as inductives rather
than functions because I find inversion really convenient.
Hope this helps,
Stéphane L.
- [Coq-Club] List OrderedType as OrderedType?, M. Scott Doerrie
- Re: [Coq-Club] List OrderedType as OrderedType?,
Pierre Letouzey
Stéphane Lescuyer
- Re: [Coq-Club] List OrderedType as OrderedType?, M. Scott Doerrie
- Re: [Coq-Club] List OrderedType as OrderedType?, Stéphane Lescuyer
Stéphane Lescuyer
Pierre Letouzey
