coq-club - Re: [Coq-Club] List OrderedType as OrderedType?
chronological Thread
  • To: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] List OrderedType as OrderedType?
  • Date: Wed, 26 Nov 2008 15:00:38 -0500
Thank you. That's what I was looking for.
Scott Doerrie
Pierre Letouzey wrote:
On Tue, Nov 25, 2008 at 02:56:21PM -0500, M. Scott Doerrie wrote:
I've been searching the Coq standard library and have been unable to find a functor that creates an OrderedType given an FSet or even a List of OrderedTypes. This seems relatively straightforward given the implementation of PairOrderedType, so I've probably missed it. I'd rather not duplicate effort, so I thought I'd ask first.
Scott Doerrie
Well, if I remember correctly, the signature FSetInterface.S contains
a compare function in particular, and others things required in a
OrderedType, so any instance of this signature can be seen as an
OrderedType by mere subtyping. This allows in particular to freely
create sets of sets, or sets of sets of sets, and so on :
Require Import FSets.
Module NatSet := FSetAVL.Make Nat_as_OT.
Module NatSetSet := FSetAVL.Make NatSet. (* here NatSet is seen as an
OrderedType *)
Concerning lists of OrderedType.t, FSetList.Make is building a
FSetInterface.S whose base type is a sorted list attached with its
sortedness proof. As before, this FSetInterface.S can be seen as an
OrderedType. If you want to deal with arbitrary lists and not only the
sorted ones, nothing exists yet in the standard library, but it should
not be too difficult to build something (indeed, PairOrderedType can
be a good source of inspiration). If you write this kind of functor,
let me know, it might be interesting to include it in the standard
library.
Best regards,
Pierre Letouzey
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
