coq-club - Re: [Coq-Club] inductive predicate over infinite objects
chronological Thread
  • To: Keiko Nakata <keiko AT kurims.kyoto-u.ac.jp>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] inductive predicate over infinite objects
  • Date: Tue, 20 Jan 2009 07:44:01 -0500
I suspect that your question is related to continuity.
Streams over A are (extensionally) isomorphic to (Nat -> Nat). Any function of type (Nat -> Nat) -> Nat can only access a finite segment of its input. This is known as "local continuity" or formally
forall f:Nat -> Nat, exists n:Nat, forall g,h : Nat, -> Nat,(forall i:Nat,i < n -> g i = h i) -> f g = f h
This is is not provable in Coq but it could be added as an axiom.
Cheers,
Thorsten
On 20 Jan 2009, at 04:20, Keiko Nakata wrote:
Hello.
At the risk of exposing my ignorance...
Is it correct that:
Suppose P is a predicate on possibly infinite lists, e.g. LList in CoqArt,
and (P x) holds for some x.
If the definition of P only "involves" induction,
then there is a finite prefix x' of x such that (P x') holds.
Assuming it correct, what would "involves" precisely mean?
And how I might be able to state it in Coq?
With best regards,
Keiko
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
