[Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types
chronological Thread
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types
- Date: Mon, 02 Feb 2009 05:43:14 +0200
Hello everybody.
I'm trying to prove equality of tuples with dependent types (a type of 'b' depends on a value of 'a'). Two 'Build_t ...'-s should be equal: a0 = (fun a => a0 a) because of the first assumption and 'b' components are equal by definition. (It's just a simplified version for test purposes which does not make any sense.)
Record t:Type := {a:nat->Set; b:forall n, a n}.
Variable (a0:nat->Set) (b0:forall n, (fun a => a0 a) n).
Definition subst : forall (eq0:a0 = (fun a => a0 a)),
Build_t a0 b0 = Build_t (fun a => a0 a) b0.
Proof.
refine (fun eq0 => _).
Set Printing All.
refine (match eq0 in _=dep
return Build_t a0 b0 = Build_t dep b0
with refl_equal => _ end).
I get
The term "b0" has type "forall n : nat, (fun a : nat => a0 a) n"
while it is expected to have type "forall n : nat, dep n"
But types in question are beta-convertible:
dep=(fun a => a0 a) \/ dep=a0
-> (forall n : nat, (fun a : nat => a0 a) n)
= (forall n : nat, a0 n)
= (forall n : nat, dep n)
Please can someone explain how Coq's type-checker works here? It is trickier than I thought.
Best regards,
Roman Beslik.
- [Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types, Roman Beslik
