Re: [Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types
chronological Thread
- To: Roman Beslik <beroal AT ukr.net>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types
- Date: Mon, 02 Feb 2009 10:14:16 -0500
Roman Beslik wrote:
I'm trying to prove equality of tuples with dependent types (a type of 'b' depends on a value of 'a'). Two 'Build_t ...'-s should be equal: a0 = (fun a => a0 a) because of the first assumption and 'b' components are equal by definition. (It's just a simplified version for test purposes which does not make any sense.)
Record t:Type := {a:nat->Set; b:forall n, a n}.
Variable (a0:nat->Set) (b0:forall n, (fun a => a0 a) n).
Definition subst : forall (eq0:a0 = (fun a => a0 a)),
Build_t a0 b0 = Build_t (fun a => a0 a) b0.
Proof.
refine (fun eq0 => _).
Set Printing All.
refine (match eq0 in _=dep
return Build_t a0 b0 = Build_t dep b0
with refl_equal => _ end).
I get
The term "b0" has type "forall n : nat, (fun a : nat => a0 a) n"
while it is expected to have type "forall n : nat, dep n"
The important point here is that the [return] clause must be type-checked independently before it can be used. During that checking, nothing is known about the variable [dep] but its type, and that type does not imply the equality that you wish held.
Here's a proof that I came up with:
Theorem subst : forall (eq0:a0 = (fun a => a0 a)),
intros.
generalize b0.
rewrite eq0.
reflexivity.
Qed.
There is more discussion of the importance of generalization in my draft textbook:
http://adam.chlipala.net/cpdt/
though I'm planning to add more coverage of the subject in the next few months.
- [Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types, Roman Beslik
- Re: [Coq-Club] dependent tuple, pattern-matching, extensional equality of functions, equal types, Adam Chlipala
