- To: "JAEGER, Eric (SGDN)" <eric.jaeger AT sgdn.gouv.fr>
- Cc: <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Question about tactics and conversions
- Date: Mon, 2 Feb 2009 22:52:06 +0100
Le 2 févr. 09 à 10:03, JAEGER, Eric (SGDN) a écrit :
Hi,
(Warning : my text IS confusing, sorry for that, so you can skip it and go below the line to see the real question).
I've encountered a small difficulty when dealing with tactics in a development using intensively notations, coercions, and decision functions. Basically, I'm trying to write a tactic looking for hypothesis of the form "f(CONS t)" where f is a transparent function and CONS a constructor - to simplify this hypothesis into a simpler one (or several simpler ones). I have a proof of "my_simpl:forall (t:T)(s:S), f(CONS t)=s->f(t)=s".
However, when I'm trying to write s.t. like:
repeat (match goal with | Hfr:f(CONS _)=_ => generalize (my_simpl _ _ Hfr); clear Hfr; intros Hfr)
This does not work... Probably because my function f defined as a fixpoint can be simplified such that f(CONS t)=f(COER t)=f'(t) (COER being a coercion). So it seems that there are conversions going on preventing the match.
I don't think [match goal] involves any conversion but it does not typecheck patterns either.
You may want to use the [Debug On] command to investigate the bug further. After this command,
you have to switch to the *coq* buffer (in ProofGeneral, don't know about coqide) to enter the
debug mode of Ltac. You have to reissue a [Debug Off] command to get out of it, it has a
non-undoable side-effect.
Hope this helps,
-- Matthieu
- [Coq-Club] Question about tactics and conversions, JAEGER, Eric (SGDN)
- Re: [Coq-Club] Question about tactics and conversions, Yves Bertot
- Re: [Coq-Club] Question about tactics and conversions, Matthieu Sozeau
JAEGER, Eric (SGDN)
Yves Bertot
JAEGER, Eric (SGDN)
JAEGER, Eric (SGDN)
Yves Bertot
JAEGER, Eric (SGDN)
