coq-club - Re: [Coq-Club] Question about tactics and conversions
chronological Thread
  • From: "JAEGER, Eric (SGDN)" <eric.jaeger AT sgdn.gouv.fr>
  • To: "Matthieu Sozeau" <Matthieu.Sozeau AT lri.fr>
  • Cc: <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Question about tactics and conversions
  • Date: Tue, 3 Feb 2009 09:21:13 +0100
Thanks for your answers... It seems that I'm looking for non existing features of Ltac (for now).
I cannot use [Debug On] because I'm working with CoqIde (Windows version, that does not help either ;-) ), but your comment on typechecking is probably a solution to my problem.
Indeed, may be I should make explicit coercions in my tactic : f(COER t) instead of f(t). If the pattern matching does not typecheck it may not be fully aware of coercions (coercions being, if I understood correctly, introduced as required to typecheck)... and may try to reduce expressions to match, and that is probably the source of my difficulty.
   Regards, Eric
----- Original Message ----- From: "Matthieu Sozeau" <Matthieu.Sozeau AT lri.fr>
To: "JAEGER, Eric (SGDN)"
Cc:
Sent: Monday, February 02, 2009 10:52 PM
I don't think [match goal] involves any conversion but it does not
typecheck patterns either.
You may want to use the [Debug On] command to investigate the bug
further. After this command,
you have to switch to the *coq* buffer (in ProofGeneral, don't know
about coqide) to enter the
debug mode of Ltac. You have to reissue a [Debug Off] command to get
out of it, it has a
non-undoable side-effect.
Hope this helps,
-- Matthieu
