- From: "JAEGER, Eric (SGDN)" <eric.jaeger AT sgdn.gouv.fr>
- To: "Yves Bertot" <Yves.Bertot AT sophia.inria.fr>
- Cc: "Matthieu Sozeau" <Matthieu.Sozeau AT lri.fr>, <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Question about tactics and conversions
- Date: Tue, 3 Feb 2009 11:09:48 +0100
Hi again,
Attached below is a piece of code that tries to capture the problem I have in a simplified manner.
I use a type lift_nat with a coercion from nat to lift_nat, and wants to perform a simplification of functional
expressions - not using "simpl" but "lift_simpl" (to keep coercions, notations, and so on, because the simplified
versions of such expressions in my development are much uglier than the original ones).
The first try is the tactic "my_simpl1", that just does not work. As mentionned by Matthieu, this is probably related
to the absence of typechecking and therefore the absence of coercions preventing the match.
The version "my_simpl2" is more generic, capturing ANY use of the function, but then trying to apply "lift_simpl".
Note that while the pattern matching does not cause reductions (conversions), trying to apply lift_simpl may have
such side-effects. Indeed, for example if I have "H:lift_alwaystrue n=true", I can do "generalize (lift_simpl _ H)";
the term "(lift_simpl _ H)" implies a reduction... That's the type of reduction I would like to avoid, because my
tactic is far less precise than I've expected (I do not blame Ltac, but my use of Ltac) - indeed, the match capture
any use of the function, but I would like then to try applying lift_simpl to discriminate hypotheses that can be
simplified, and only those.
The version "my_simpl3" is again derived from "my_simpl1", but making explicit the coercion, and
"my_simpl4" is derived from "my_simpl2".
my_simpl2, 3 and 4 succeed in proving theorem test. Unfortunately I've to use them several times, because using "repeat" causes a crash. Using the proposal of Yves (generalising, clearing) I may avoid the problem.
Yet I do not understand the behaviour of my_simpl2, 3 and 4 in test'... How may I have different messages, one
indicating success, the other failure? There is backtracking going on here, but that does not give me any clue about what is happening.
I hope to be clearer now ;-)
Regards, Eric
Inductive lift_nat:Set := ln:nat->lift_nat.
Coercion ln:nat>->lift_nat.
Fixpoint alwaystrue(n:nat){struct n}:bool :=
match n with
| O => true
| S n'=> alwaystrue n'
end.
Definition lift_alwaystrue(n:lift_nat):bool := match n with ln n' => alwaystrue n' end.
Theorem lift_simpl:forall (n:nat), lift_alwaystrue(S n)=true->lift_alwaystrue(n)=true.
Proof.
intros n HS; apply HS.
Qed.
Ltac my_simpl1:=
match goal with
| Hfr:(lift_alwaystrue (S _)=_) |- _ => generalize (lift_simpl _ Hfr); clear Hfr; intros Hfr;
idtac "my_simpl1: match"
| _ => idtac "my_simpl1: no match"
end.
Ltac my_simpl2:=
match goal with
| Hfr:(lift_alwaystrue (_)=_) |- _ => (generalize (lift_simpl _ Hfr); clear Hfr; intros Hfr;
idtac "my_simpl2: match ok") ||
idtac "my_simpl2: match fail"
| _ => idtac "my_simpl2: no match"
end.
Ltac my_simpl3:=
match goal with
| Hfr:(lift_alwaystrue (ln (S _))=_) |- _ => (generalize (lift_simpl _ Hfr); clear Hfr; intros Hfr;
idtac "my_simpl3: match ok") ||
idtac "my_simpl3: match fail"
| _ => idtac "my_simpl3: no match"
end.
Ltac my_simpl4:=
match goal with
| Hfr:(lift_alwaystrue (ln _)=_) |- _ => (generalize (lift_simpl _ Hfr); clear Hfr; intros Hfr;
idtac "my_simpl4: match ok") ||
idtac "my_simpl4: match fail"
| _ => idtac "my_simpl4: no match"
end.
Theorem test:forall (n:nat), lift_alwaystrue(S (S n))=true->lift_alwaystrue(n)=true.
Proof.
intros n H.
(* my_simpl1. -- Prompts "my_simpl1: no match", does nothing *)
(* my_simpl2. -- Prompts "my_simpl2: match ok", simplifies H *)
(* my_simpl3. -- Prompts "my_simpl3: match ok", simplifies H *)
(* my_simpl4. -- Prompts "my_simpl4: match ok", simplifies H *)
my_simpl2; my_simpl2; apply H.
Qed.
Variable g:nat->nat.
Theorem test':forall (n:nat), lift_alwaystrue(g n)=true->lift_alwaystrue(n)=true.
Proof.
intros n H.
(* my_simpl2. -- Prompts "my_simpl2: match ok" AND "my_simpl2:match fail", does nothing *)
(* my_simpl3. -- Prompts "my_simpl3: no match", does nothing *)
(* my_simpl4. -- Prompts "my_simpl4: match ok" AND "my_simpl2:match fail", does nothing *)
Admitted.
----- Original Message ----- From: "Yves Bertot" <Yves.Bertot AT sophia.inria.fr>
To: "JAEGER, Eric (SGDN)"
<Matthieu.Sozeau AT lri.fr>;
Sent: Tuesday, February 03, 2009 10:18 AM
Indeed, may be I should make explicit coercions in my tactic : f(COER t) instead of f(t). If the pattern matching does not typecheck it may not be fully aware of coercions (coercions being, if I understood correctly, introduced as required to typecheck)... and may try to reduce expressions to match, and that is probably the source of my difficulty.Well, as Mathieu said, there should not be any reduction happening. This should not be the problem...
Regards, Eric
- [Coq-Club] Question about tactics and conversions, JAEGER, Eric (SGDN)
- Re: [Coq-Club] Question about tactics and conversions, Yves Bertot
Matthieu Sozeau
JAEGER, Eric (SGDN)
Yves Bertot
- Re: [Coq-Club] Question about tactics and conversions, JAEGER, Eric (SGDN)
- Re: [Coq-Club] Question about tactics and conversions, Matthieu Sozeau
Yves Bertot
JAEGER, Eric (SGDN)
