- From: Rohit Persaud <persaud.rohit AT googlemail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] strange recursive error
- Date: Tue, 17 Feb 2009 11:39:21 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=BE/gzOCQ8Mnd49m59qrXw/hZsBiCzgL60KklPWMkbDO2H6QcNHKibwHC/gfa1f/AMD 3aXZ2aAkYaBT/k09FA7lMBSpoynmIX1LasWu/Nbv4iwRdf3ydCmEeczV8U5ZfKRB426s J7Bezfpnq2sRcet3sCiZ76VRZN5HzLW3EdqrU=
Hi There,
I am having trouble defining the following function in Coq, and would greatly appreciate any advice.
Given the family of types :
Inductive T : Set :=
| T1 : T
| TN : T
| TP : T -> T -> T
| TS : T -> T -> T.
(* here is the interpretation of T, just for guidance :
Inductive Tint : T -> Set :=
| Tunit : Tint T1
| Tnat : nat -> Tint TN
| Tinl : forall t1, Tint t1 -> forall t2, Tint (TS t1 t2)
| Tinr : forall t2, Tint t2 -> forall t1, Tint (TS t1 t2)
| Tprod : forall t1, Tint t1 -> forall t2, Tint t2 -> Tint (TP t1 t2).
and the types of functions over this family (these actually are of a special form, such that functions from nat -> nat are decidable) :
Inductive POLY (I : T) : T -> Set :=
| Punit : POLY I T1
| PA : nat -> POLY I TN
| PProdI : forall X B, POLY I X -> POLY I B -> POLY I (TP X B)
| PSum1 : forall X B, POLY I X -> POLY I (TS X B)
| PSum2 : forall X B, POLY I B -> POLY I (TS X B).
Infix " ===> " := POLY (at level 15).
we wish to decide equality on these functions: Pol_eq (I J: T) : POLY I J -> POLY I J -> bool.
It is clear how to define equality into the unit and product types, and we assume we know how to decide functions of type POLY TN TN. Two
functions from a sum type are equal iff their respective projections are equal.
Given the following definitions :
(* views *)
Inductive POLYS (I A B: T) : I ===> (TS A B) -> Set :=
| pleft : forall (i: POLY I A), POLYS (PSum1 B i )
| pright : forall (i: POLY I B), POLYS (PSum2 A i).
Definition polyys (I A B : T) (i : I ===> (TS A B)) : POLYS i :=
match i in POLY _ e return match e return (POLY I e) -> Set with
| TS _ _ => @POLYS I _ _
| _ => fun _ => unit
end i with
| PSum1 _ b X => pleft _ X
| PSum2 a _ X => pright _ X
| _ => tt
end.
Fixpoint Pin1 (A B C : T) (i : (TS A B) ===> C) {struct i} : A ===> C :=
match i in (_ ===> e) return (A ===> e) with
| Punit => Punit A
| PA n => PA A n
| PProdI _ _ Ia Ib => PProdI (Pin1 Ia ) (Pin1 Ib)
| PSum1 _ X Ia => PSum1 X (Pin1 Ia)
| PSum2 X _ Ib => PSum2 X (Pin1 Ib)
end.
Fixpoint Pin2 (A B C : T) (i : (TS A B) ===> C) {struct i} : B ===> C :=
match i in (_ ===> e) return (B ===> e) with
| Punit => Punit B
| PA n => PA B n
| PProdI _ _ Ia Ib => PProdI (Pin2 Ia ) (Pin2 Ib)
| PSum1 _ X Ia => PSum1 X (Pin2 Ia)
| PSum2 X _ Ib => PSum2 X (Pin2 Ib)
end.
Fixpoint Pout1 (A B C : T) (i : A ===> C) {struct i} : TS B A ===> C :=
match i in (_ ===> e) return (TS B A ===> e) with
| Punit => Punit (TS B A)
| PA n => PA (TS B A) n
| PProdI _ _ Ia Ib => PProdI (Pout1 B Ia ) (Pout1 B Ib)
| PSum1 _ X Ia => PSum1 X (Pout1 B Ia)
| PSum2 X _ Ib => PSum2 X (Pout1 B Ib)
end.
Fixpoint Pout2 (A B C : T) (i : A ===> C) {struct i} : TS A B ===> C :=
match i in (_ ===> e) return (TS A B ===> e) with
| Punit => Punit (TS A B)
| PA n => PA (TS A B) n
| PProdI _ _ Ia Ib => PProdI (Pout2 B Ia ) (Pout2 B Ib)
| PSum1 _ X Ia => PSum1 X (Pout2 B Ia)
| PSum2 X _ Ib => PSum2 X (Pout2 B Ib)
end.
Fixpoint EqSum (A B : T) {struct A} : (POLY A B -> POLY A B -> bool)
-> POLY A B -> POLY A B -> bool :=
match A as e return ((POLY e B -> POLY e B -> bool) -> POLY e B -> POLY e B -> bool) with
| TS X Y => fun H f g =>
EqSum (fun i j => H (Pout1 Y i) (Pout1 Y j)) (Pin1 f) (Pin1 g)
EqSum (fun i j => H (Pout2 X i) (Pout2 X j)) (Pin2 f) (Pin2 g)
| _ => fun H i j => H i j
end.
Now when i define the function :
Fixpoint Pol_eq (I J: T) (i : POLY I J) {struct i} : POLY I J -> bool :=
match i in POLY _ e return (POLY _ e -> bool) with
| PA n => fun _ => true
| PProdI _ _ Ia Ib => fun _ => true
| Punit => fun _ => true
| PSum1 X Y Ib => fun x =>
match polyys x with
| pleft pl => EqSum (Pol_eq (I := I) (J := X)) Ib pl
| _ => false
end
| PSum2 X Y Ib => fun _ => true
end.
( * note the implementations at the branches are replaced by true for brevity *)
I get the following error "Recursive call to Pol_eq had not enough arguments " . Shouldn't this function be fine?
Is there any way around this.
Many Thanks,
Rohit.
- [Coq-Club] strange recursive error, Rohit Persaud
- <Possible follow-ups>
Rohit Persaud
- Re: [Coq-Club] strange recursive error,
Adam Chlipala
- Re: [Coq-Club] strange recursive error, Rohit Persaud
Adam Chlipala
