- From: Rohit Persaud <persaud.rohit AT googlemail.com>
- To: Adam Chlipala <adamc AT hcoop.net>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] strange recursive error
- Date: Thu, 19 Feb 2009 11:21:17 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=TwZ5CHljVAVfvpyWGSzsWmLVUevng9aEAN3GgBaa9ry6gn1kDZP4brwCcaEWpjXaop ta3Zr/uN9iTkHnE9yMpNA2A4l09r5Yx2AJaIdfpY8zPojMFAgRTaP5TG4rI7dqvhqxjV 2yXTTRtsuyUp3h3eoTyZSpibm9YcplF9QvaF4=
Thanks Adam, but I did manage to figure out what was wrong.
The purpose of the EqSum function is to recursively apply Pol_eq to the respective projections of functions like A + B -> C, namely A -> C and B -> C. So given two functions of type
I -> X + Y (given by PSum1 X Y Ia and PSum1 X Y Ib, with Ia and Ib being the injections
I -> A and I -> B, respectively) we wish to decompose I, applying Pol_eq to its respective components. It only matters if I is a sum type, say P + Q, in which case we need to apply Pol_eq to the projections P -> A, Q -> A, P -> B and Q -> B. Otherwise, I needs no decomposition and Pol_eq is applied to the respective injections.
Indeed you are correct in stating that the recursive calls to Pol_eq need the arguments explicitly (Obviously! but i think I've seen some coq code somewhere where something similar was done but, come to think of it, I can't remember checking if the code actually works!). Anyway the following function achieves my objectives:
Fixpoint Pol_eq (I J: T) (i : POLY I J) {struct i} : POLY I J -> bool :=
match i in POLY _ e return (POLY _ e -> bool) with
| PA n => fun _ => true
| PProdI _ _ Ia Ib => fun _ => true
| Punit => fun _ => true
| PSum1 X Y Ib => fun x =>
match polyys x with
| pleft pl => EqSum (fun _ _ => Pol_eq Ib pl) Ib pl
| _ => false
end
| PSum2 X Y Ib => fun _ => true
end.
Rohit.
On Wed, Feb 18, 2009 at 8:51 PM, Adam Chlipala <adamc AT hcoop.net> wrote:
Rohit Persaud wrote:
Now when i define the function :
No, it shouldn't be fine. Any call to a recursive function must include the recursive argument explicitly, since this is needed for termination checking.| PSum1 X Y Ib => fun x => match polyys x with
| pleft pl => EqSum (Pol_eq (I := I) (J := X)) Ib pl
| _ => false
end
end.
( * note the implementations at the branches are replaced by true for brevity *)
I get the following error "Recursive call to Pol_eq had not enough arguments " . Shouldn't this function be fine?
I haven't followed the details of what you're trying to do, but it seems plausible that your function might be primitive-recursive in either [I] or [J]. You could try changing the [struct] annotation to reflect that. This might require more dependent types tricks than you have now.
Is there any way around this.
- [Coq-Club] strange recursive error, Rohit Persaud
- <Possible follow-ups>
Rohit Persaud
- Re: [Coq-Club] strange recursive error,
Adam Chlipala
- Re: [Coq-Club] strange recursive error, Rohit Persaud
Adam Chlipala
