coq-club - Re: [Coq-Club] strange recursive error
chronological Thread
  • To: Rohit Persaud <persaud.rohit AT googlemail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] strange recursive error
  • Date: Wed, 18 Feb 2009 15:51:10 -0500
Rohit Persaud wrote:
Now when i define the function :
Fixpoint Pol_eq (I J: T) (i : POLY I J) {struct i} : POLY I J -> bool :=
     match i in POLY _ e return (POLY _ e -> bool)   with
     | PA n => fun _ => true
     | PProdI _ _ Ia Ib =>    fun _ => true
| Punit => fun _ => true | PSum1 X Y Ib => fun x => match polyys x with
| pleft pl => EqSum (Pol_eq (I := I) (J := X)) Ib pl
                     |  _       => false
                     end
     | PSum2 X Y Ib => fun _ => true
    end.
( * note the implementations at the branches are replaced by true for brevity *)
I get the following error "Recursive call to Pol_eq had not enough arguments " . Shouldn't this function be fine?
No, it shouldn't be fine. Any call to a recursive function must include the recursive argument explicitly, since this is needed for termination checking.
 Is there any way around this.
I haven't followed the details of what you're trying to do, but it seems plausible that your function might be primitive-recursive in either [I] or [J]. You could try changing the [struct] annotation to reflect that. This might require more dependent types tricks than you have now.
