- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] a newbie question
- Date: Thu, 19 Feb 2009 18:19:29 -0800 (PST)
Mr. Bertot,
Thank you for the kind answers and advice.
Yves Bertot wrote:
> ohpato wrote:
>> Hello,
>> I am a newbie just started studying Coq and formal methods.
>> Today I defined a record type as follows:
>> Record Record_T : Type := mkRecord_T {
>> rcdID : RecordID_T;
>> field : Field_T;
>> and declared axioms (decidability of equality) for two fields like:
>> Axiom rcdid_eq_dec:
>> forall rid rid':RecordID_T, {rid = rid'} + {rid <> rid'}.
>> Axiom fieldT_eq_dec:
>> forall ft ft':Field_T, {ft = ft'} + {ft <> ft'}.
>> and I could prove
>> Lemma RecordId_is_equal_when_Record_is_equal:
>> forall (r r':Record_T),
>> r = r' -> (rcdID r) = (rcdID r')
>> Now, I have some questions. (The questions might be very basic and
>> well-known. Sorry for my ignorance in that case.)
>> - Q1:
>> By doing the above, I assume a (rcdID:RecordID_T) is unique and
>> distinguishable from others (e.g. rcdID':RecordID_T). Am I right?
> I don't know what you mean by being unique. I agree that assuming
> rcdid_eq_dec, you do say elements of RecodedID_T can be distinguished
> from others using this function, but I don't know how to connect this
> notion with the word "unique".
>> - Q2:
>> If so, I wanted to have the following properties additionally.
>> Property1)
>> Record_is_equal_when_RecoredID_is_same:
>> forall (r r':Record_T), (rcdID r) = (rcdID r') -> r = r'.
> This property is probably wrong, as soon as your type Record_T contains
> two distinguishable elements (elements f1 and f2 such that f1 <> f2),
> you can construct two elements of Record_ID that share the same first
> component and have different second components, these records are
> provably different. If you add this property as an axiom, you will get
> an inconsistent logic, this kills the purpose of using a proof system.
>> Property2)
>> recored_eq)dec:
>> forall (r r':Recored_T), {r = r'} + {r <> r'}.
> This property is a consequence from rcdid_eq_dec and fieldT_q_dec.
>> I think Property1 should be declared as an Axiom. If I do that,
>> can Property2 be proved as a lemma? (or is Vice Versa possible??)
> As already said, property1 is dangerous and property2 can already be
> derived from other assumptions.
>> or shall I make both of them as Axioms?
> As a beginner, you should consider that axioms are not for you. Try to
> get acquainted with the system first, and you may discover that you will
> never need axioms. The only place where axioms are perfectly legitimate
> is in module interfaces, but then these module interfaces are supposed
> to be fulfilled by module implementations and in this sense they are not
> really axioms.
>> Thanks in advance.
> Bug reports: http://logical.saclay.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
View this message in context:
http://www.nabble.com/a-newbie-question-tp22095657p22113648.html
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] a newbie question, ohpato
- Re: [Coq-Club] a newbie question,
Yves Bertot
- Re: [Coq-Club] a newbie question, ohpato
- Re: [Coq-Club] a newbie question, Yves Bertot
Yves Bertot
