- To: ohpato <ohpato AT hanmail.net>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] a newbie question
- Date: Fri, 20 Feb 2009 10:13:08 +0100
ohpato wrote:
Mr. Bertot,Don't thank me too much, I got the name of various types wrong, so that my message
Thank you for the kind answers and advice.
may have been a little confusing.
Yves Bertot wrote:In this sentence, Record_T should have been Field_T, and Record_ID should have been
ohpato wrote:
This property is probably wrong, as soon as your type Record_T contains two distinguishable elements (elements f1 and f2 such that f1 <> f2), you can construct two elements of Record_ID that share the same first component and have different second components, these records are provably different. If you add this property as an axiom, you will get an inconsistent logic, this kills the purpose of using a proof system.
Record_T...
My mistake,
Yves
- [Coq-Club] a newbie question, ohpato
- Re: [Coq-Club] a newbie question,
Yves Bertot
ohpato
- Re: [Coq-Club] a newbie question, Yves Bertot
ohpato
Yves Bertot
