- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] a newbie question
- Date: Thu, 19 Feb 2009 00:05:55 -0800 (PST)
Hello,
I am a newbie just started studying Coq and formal methods.
Today I defined a record type as follows:
Record Record_T : Type := mkRecord_T {
rcdID : RecordID_T;
field : Field_T;
and declared axioms (decidability of equality) for two fields like:
Axiom rcdid_eq_dec:
forall rid rid':RecordID_T, {rid = rid'} + {rid <> rid'}.
Axiom fieldT_eq_dec:
forall ft ft':Field_T, {ft = ft'} + {ft <> ft'}.
and I could prove
Lemma RecordId_is_equal_when_Record_is_equal:
forall (r r':Record_T),
r = r' -> (rcdID r) = (rcdID r')
Now, I have some questions. (The questions might be very basic and
well-known. Sorry for my ignorance in that case.)
- Q1:
By doing the above, I assume a (rcdID:RecordID_T) is unique and
distinguishable from others (e.g. rcdID':RecordID_T). Am I right?
- Q2:
If so, I wanted to have the following properties additionally.
Property1)
Record_is_equal_when_RecoredID_is_same:
forall (r r':Record_T), (rcdID r) = (rcdID r') -> r = r'.
Property2)
recored_eq)dec:
forall (r r':Recored_T), {r = r'} + {r <> r'}.
I think Property1 should be declared as an Axiom. If I do that,
can Property2 be proved as a lemma? (or is Vice Versa possible??)
or shall I make both of them as Axioms?
Thanks in advance.
View this message in context:
http://www.nabble.com/a-newbie-question-tp22095657p22095657.html
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] a newbie question, ohpato
- Re: [Coq-Club] a newbie question,
Yves Bertot
ohpato
- Re: [Coq-Club] a newbie question, Yves Bertot
ohpato
Yves Bertot
