coq-club - Re: [Coq-Club] Data Structures
chronological Thread
  • From: Frederic Blanqui <frederic.blanqui AT inria.fr>
  • To: Adam Koprowski <adam.koprowski AT gmail.com>
  • Cc: dimitrisg7 <dvekris AT hotmail.com>, Edsko de Vries <devriese AT cs.tcd.ie>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Data Structures
  • Date: Wed, 18 Mar 2009 09:31:34 +0800
Adam Koprowski a écrit :
On Mon, Mar 16, 2009 at 17:28, dimitrisg7 <dvekris AT hotmail.com <mailto:dvekris AT hotmail.com>> wrote:
    [...] I would be happy if I could have something like:
    Inductive data_prop ...
    with Fixpoint func (data_prop).
That's a very good question indeed. I was wondering about that myself. In my work I'll also need an inductively defined tree-like data-structure whose component's type depends on the subtree, hence I'd like to compute it with a (mutually recursive) Fixpoint function.
Are there any theoretical concerns when combining Inductive and Fixpoint definitions or is it not possible to do that in Coq for technical reasons only? Any neat way to side-step this limitation? The obvious one is to turn the Fixpoint function into a relation and define it inductively, but that makes instantiating and working with such data-types much less pleasent...
This kind of definition is called "inductive-recursive" in the literature. This is not a theoretical problem. See for instance http://pauillac.inria.fr/coq/mailing-lists/coqclub/200210/msg00025.html for some discussion about that.
