- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Data Structures
- Date: Mon, 16 Mar 2009 08:23:20 -0700 (PDT)
You have both been really helpful! Thanks a lot.
> As for building the property into list, if I understand you correctly,
> what would you say about this:
> Inductive data_prop (m : nat) : nat -> Set :=
> | dp_nil : data_prop m 0
> | dp_cons : forall el, func el < m -> data_prop m 0 -> data_prop m 0
> | dp_consX : forall el i, func el = m -> data_prop m i -> data_prop m (S
> i).
> 'data_prop m l' gives you a list with your property with parameters 'm'
> and 'l'.
Especially your piece of advice has been really inspiring Adam. What I
actually need is
Variable func : nat -> nat.
| dp_cons : forall el i, func el < m -> data_prop m i -> data_prop m (S i)
| dp_consX : forall el i, func el = m -> data_prop2 m i -> data_prop m (S i)
with data_prop2 (m : nat) : nat -> Set :=
| dp2_nil : data_prop2 m 0
| dp2_consX : forall el i, func el = m -> data_prop2 m i -> data_prop2 m (S
i).
where i and S i are indexes.
I changed the type of func to nat->nat, which is actually wrong just to help
Coq typecheck. What I need is a "func" dependent on data_prop. "func" uses
recursively data_prop. Is it possible to define a fixpoint dependent on an
inductive definition, which also calls this fixpoint? I hope I am clear. Am
I getting to "dependent"? The last question applies to the experienced users
of Coq.
View this message in context:
http://www.nabble.com/Data-Structures-tp22535211p22540515.html
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] Data Structures, Dimitris Vekris
- Re: [Coq-Club] Data Structures, Edsko de Vries
Adam Koprowski
- Re: [Coq-Club] Data Structures, dimitrisg7
muad
dimitrisg7
Adam Koprowski
- Re: [Coq-Club] Data Structures, Adam Chlipala
muad
- Re: [Coq-Club] Data Structures, Frederic Blanqui
dimitrisg7
muad
- <Possible follow-ups>
- [Coq-Club] Data structures, dimitrisg7
