coq-club - Re: [Coq-Club] Data Structures
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Data Structures
  • Date: Mon, 16 Mar 2009 09:28:32 -0700 (PDT)
muad wrote:
> What sort of properties to do you expect of this though, and what proofs
> do you want want to make? (I could not suggest something without knowing
> what you are doing, in a bit more detail).
Well, I must prove that a certain transformation from a source language to a
target one preserves the semantics. "data_prop" refers to the type of some
objects the source language has. "data_prop" has the property mentioned
above and I thought that this should be reflected in the initial definition
and not given as a separate hypothesis. What makes things complicated is
function "func", which is actually the order of the type and uses
recursively "data_prop". I would be happy if I could have something like:
Inductive data_prop ...
with Fixpoint func (data_prop).
View this message in context:
http://www.nabble.com/Data-Structures-tp22535211p22541211.html
Sent from the Coq mailing list archive at Nabble.com.
