- To: Pierre.Corbineau AT imag.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] C-zar proof help
- Date: Fri, 20 Mar 2009 00:55:12 +0000
On Thu, Mar 19, 2009 at 08:35:29PM +0100, Pierre Corbineau wrote:
> in the second case :
> The problem has to do with the automation used (the congruence tactic
> doesn't rewrite in match...with).
> a workaround :
Thanks, that worked.
Is this a fundamental problem, or will it be fixed (so that the
workaround is not needed) in a future release?
Would I have more luck if I used the development version of coq?
Thanks
Ian
- Re: [Coq-Club] C-zar proof help, (continued)
Taral
Ian Lynagh
Taral
- Re: [Coq-Club] C-zar proof help, Ian Lynagh
- Re: [Coq-Club] C-zar proof help, Hugo Herbelin
- Re: [Coq-Club] C-zar proof help, Pierre Corbineau
- Re: [Coq-Club] C-zar proof help, Sean Wilson
Taral
Ian Lynagh
Taral
Pierre Corbineau
- Re: [Coq-Club] C-zar proof help, Taral
