- To: Ian Lynagh <igloo AT earth.li>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] C-zar proof help
- Date: Wed, 4 Mar 2009 16:01:01 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=uYB4GDd6Ub7V/wvGHNMzeJ+AumFCjNLD+iTSfUP2gc2zClowa0ERz+FlqoU99E6wUc ldc0g299BBLI0r2GeO1r4NGxUjOTvZujxDXfG1sVo+Qd60r4nJ8/GYBB9v4UEDLk8fnU 5J7Lvv9zeEWHItF/LGdYQbAxj6VL5J+FqJuKk=
On Wed, Mar 4, 2009 at 8:38 AM, Ian Lynagh
<igloo AT earth.li>
wrote:
> You mean I can't do the
> be such that (namedCommute (p, q) = Some (q', p')).
> step, right? It's not obvious to me why that shouldn't also work.
That's right. The reason is that the induction steps do not substitute
into hypotheses, so you have to keep it in the goal as an implication
until you're done with your induction steps.
> If I understand you correctly, this is one of the things that confuses
> me too. e.g. in the following lemma, the last line goes orange, whereas
> I would expect it to be green:
> Lemma Foo : forall (x : bool), ((x = true) \/ (x = false)).
> proof.
> let x : bool.
> per cases on x.
> suppose it is true.
> then (x = true).
Exactly. In Ltac, this is the difference between "case" and "case_eq".
I think it's a serious shortcoming of C-zar that it doesn't generate
the equality.
Taral
<taralx AT gmail.com>
"Please let me know if there's any further trouble I can give you."
-- Unknown
- [Coq-Club] C-zar proof help, Ian Lynagh
- Re: [Coq-Club] C-zar proof help,
Adam Chlipala
Ian Lynagh
Adam Chlipala
- Re: [Coq-Club] C-zar proof help, Ian Lynagh
Adam Chlipala
Ian Lynagh
- Re: [Coq-Club] C-zar proof help, Pierre Corbineau
- Re: [Coq-Club] C-zar proof help, Taral
Taral
Taral
Ian Lynagh
Ian Lynagh
Taral
- Re: [Coq-Club] C-zar proof help, Hugo Herbelin
- Re: [Coq-Club] C-zar proof help, Sean Wilson
Taral
Ian Lynagh
Pierre Corbineau
Ian Lynagh
Taral
Adam Chlipala
