coq-club - Re: [Coq-Club] Problems with Program.
chronological Thread
  • To: Adam Koprowski <adam.koprowski AT gmail.com>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Problems with Program.
  • Date: Wed, 25 Mar 2009 15:49:59 +0100
Le 25 mars 09 à 13:11, Adam Koprowski a écrit :
    Dear all,
Dear Adam,
I find the new Program tactic an extremely useful and powerful tool, however I do have some problems with it every once in a while. Let me illustrate it on an example - maybe some of you will be able to shed some light on my problems.
I want to define a function [check_n n P] that given a natural number [n] and a predicate [P : nat -> bool] checks whether [P] holds for all [i < n]. Easy enough, so to make things more interesting, say I also want to restrict the domain of [P] to numbers smaller than [n]. My first attempt was the following:
Program Fixpoint check_n (n : nat) (P : { i | i < n } -> bool) (p : nat) :
  Exc (forall (p : { i | i < n}), P p = true) :=
  match le_lt_dec n p with
  | left _ => value _
  | right cmp =>
      if P p then
        check_n P (S p)
      else
        error
  end.
Now Program tells me that it cannot infer the termination criteria. Fair enough. So I add the following annotation:
{measure (fun i => n - i) p}
The first unpleasant effect of this is that this actually changes the arguments of check_n (due to inner workings of handling of termination with measure by Program, I believe) and hence the recursive call needs to be changed. Too bad, but based on the error message it's possible to figure out what is expected and I change the recursive call to:
check_n (S p)
  (Why did P become implicit??).
This is indeed due to the way well-founded definitions are encoded, using
a combinator that provides a functional for recursive calls whose first
argument is the recursive argument. The way it is handled right now forces
all the previous arguments to stay constant during recursive calls. Also,
the measure function may refer only to those arguments, and not the ones
following the recursive argument. These two problems could be fixed simply
by curryfying.
Now the definition is accepted but I realize that to prove the obligations I will need to strengthen the specification of [check_n]. So I finally arrive at:
<snip/>
Invoking [intros] doesn't work which is the first indication that something funny is going on, but still it's not difficult to give a proof:
  intro H. intros. apply H0. destruct p0. simpl. omega.
Qed.
Yes, [intros] failing is a sign of ill-typedness. This (deBruijn) bug is due
to some tricky manipulations related to the above problem. Please report it.
-- Matthieu
