- From: Santiago Zanella <Santiago.Zanella AT sophia.inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Problems with Program.
- Date: Thu, 26 Mar 2009 11:13:27 +0100
In fact, you don't need any axiom to prove proof irrelevance for [lt].
Here's an axiom-free proof, inspired by a recent message on the list by
Pierre Letouzey.
(** LtIrrelevance.v : Proof irrelevance for [le] and [lt] *)
Require Export Eqdep_dec.
Require Import Arith.
Set Implicit Arguments.
Lemma nat_dec : forall n m:nat, n = m \/ n <> m.
Proof.
intros n m; destruct (eq_nat_dec n m); auto.
Qed.
Scheme le_rec := Induction for le Sort Prop.
Lemma le_inversion : forall (x y:nat) (P:le x y),
(exists H:x = y, P = eq_rect x (le x) (le_n x) y H) \/
(exists y', exists R:S y' = y, exists H:le x y',
P = eq_rect (S y') (le x) (le_S x y' H) y R).
Proof.
intros x y P.
case P; [left | intros m H; right].
exists (refl_equal x); auto.
exists m.
exists (refl_equal (S m)).
exists H; auto.
Qed.
Lemma le_irrelevance : forall (x y:nat) (p1 p2:x <= y), p1 = p2.
Proof.
intros x y p1.
elim p1 using le_rec.
intros p2.
destruct (le_inversion p2) as [(x0,H0) | (x0,(x1,(x2,_)))].
rewrite H0.
rewrite (eq_proofs_unicity nat_dec x0 (refl_equal x)); auto.
subst.
absurd (S x0 <= x0); auto with arith.
intros.
destruct (le_inversion p2) as [(x0,H0) | (x0,(x1,(x2,H0)))].
absurd (S m <= m); auto with arith.
rewrite <- x0.
assumption.
injection x1; intros; subst.
rewrite (H x2).
rewrite (eq_proofs_unicity nat_dec x1 (refl_equal (S m))).
auto.
Qed.
Lemma lt_irrelevance : forall x y (H1 H2: x < y), H1 = H2.
Proof.
intros; hnf in *.
rewrite (le_irrelevance H1 H2); reflexivity.
Qed.
Print Assumptions lt_irrelevance.
- [Coq-Club] Problems with Program., Adam Koprowski
- Re: [Coq-Club] Problems with Program.,
Matthieu Sozeau
Matthieu Sozeau
Taral
- Re: [Coq-Club] Problems with Program., Adam Chlipala
Taral
Matthieu Sozeau
- <Possible follow-ups>
- Re: [Coq-Club] Problems with Program., Santiago Zanella
Matthieu Sozeau
