- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Problems with Program.
- Date: Wed, 25 Mar 2009 17:28:24 -0400
Taral wrote:
On Wed, Mar 25, 2009 at 7:55 AM, Matthieu Sozeau
<Matthieu.Sozeau AT lri.fr>
wrote:
P.S.: and there's a workaround too:
Neat workaround.
I tried to solve this for fun, and was forced at once point to use
proof irrelevance. Ew. Anyone know a way that doesn't use that?
You can assume the weaker axiom from the [Eqdep] module, and that implies proof irrelevance for [lt], which is all that we need here. An old coq-club post gives the proof of this implication.
Here's a Program-free implementation, for the heck of it:
Axiom lt_irrel : forall n m (pf1 pf2 : n < m), pf1 = pf2.
Notation "'No'" := (right _ _).
Notation "'Yes'" := (left _ _).
Notation "'Red' e" := (if e then Yes else No) (at level 60).
Notation "'RedE' e" := (if e then value _ else error) (at level 60).
Parameter max : nat.
Parameter P : {n | n < max} -> Prop.
Parameter dec : forall x, {P x} + {~P x}.
Definition P' n := exists pf, P (exist _ n pf).
Definition dec' (x : nat) : {P' x} + {~P' x}.
Hint Extern 1 False => match goal with
| [ pf1 : ?N < ?M, pf2 : ?N < ?M |- _ ] =>
rewrite (lt_irrel N M pf1 pf2) in *
end.
intro; refine (match le_lt_dec max x with
| left _ => No
| right Hlt => Red (dec (exist (fun n => n < max) _ Hlt))
end); unfold P', not; firstorder.
Qed.
Definition total' : forall max', max' <= max -> Exc (forall x, x < max' -> P' x).
Hint Extern 1 (_ < _) => omega.
Hint Extern 1 (P' _) => elimtype False; omega.
Hint Extern 1 (P' ?X) => match goal with
| [ H : X < S ?N |- _ ] =>
destruct (eq_nat_dec X N); subst
end.
refine (fix F (max' : nat) : max' <= max -> Exc (forall x, x < max' -> P' x) :=
match max' return max' <= max -> Exc (forall x, x < max' -> P' x) with
| O => fun _ => value _
| S max' => fun _ =>
if dec' max'
then RedE (F max' _)
else error
end); intuition.
Qed.
Definition total : Exc (forall x, P x).
refine (RedE (total' max _)); intuition;
match goal with
| [ x : {n | n < max}, H : forall x, x < max -> _ |- _ ] =>
let n := fresh "n" with pf := fresh "pf"
with pf' := fresh "pf'" in
destruct x as [n pf]; destruct (H n pf) as [pf'];
rewrite (lt_irrel _ _ pf pf'); assumption
end.
Qed.
- [Coq-Club] Problems with Program., Adam Koprowski
- Re: [Coq-Club] Problems with Program.,
Matthieu Sozeau
Matthieu Sozeau
Taral
- Re: [Coq-Club] Problems with Program., Adam Chlipala
Taral
Matthieu Sozeau
- <Possible follow-ups>
- Re: [Coq-Club] Problems with Program., Santiago Zanella
Matthieu Sozeau
