- To: Frederic Blanqui <frederic.blanqui AT inria.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] relations and sections
- Date: Sat, 28 Mar 2009 12:47:17 +0100
Hello Frédéric,
Le 28 mars 09 à 04:08, Frederic Blanqui a écrit :
Hello. It seems that the declaration of relations or morphisms is not compatible with the section mechanism. When a relation or a morphism is declared inside a section, then it does not seem to be exported or redeclared as a parametric relation or morphism on the section variables it depends on. Is there any reason for that? Cheers, Frederic.
Compatibility mainly. If you use the typeclasses commands to declare them instead, you can prefix with "Global" for the redeclaration to happen. E.g, in pseudo-code:
Section foo.
Variable A : Type.
Definition my_rel : relation A.
Global Instance my_rel_equiv : Equivalence my_rel...
Definition plus : A -> A.
Global Instance plus_mor : Morphism (my_rel ==> my_rel) plus.
End foo.
-- Matthieu
- [Coq-Club] relations and sections, Frederic Blanqui
- Re: [Coq-Club] relations and sections, Matthieu Sozeau
