coq-club - Re: [Coq-Club] "setoid rewrite failed"
chronological Thread
  • To: Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] "setoid rewrite failed"
  • Date: Wed, 01 Apr 2009 13:29:57 +0200
Edsko de Vries wrote:
Hi,
Coq is giving me an error, and I'm not sure what it means. A tiny bit of context: in the proof of a simple lemma, I need to prove that
Hin : z === x
______________________________________(1/2)
List.In (x, c) ((z, c) :: l)
which surely should be easy (rewrite using Hin, since I cannot do "subst"), and then apply In_head (or whatever that lemma is called). However, calling "rewrite Hin" gives the following error:
Error: Tactic failure: setoid rewrite failed: unable to satisfy the rewriting constraints.
Unable to satisfy the following constraints:
In environment:
A : Type
B : Type
key : Type
x : key
a : A
E : list (key * A)
F : list (key * A)
G : list (key * A)
R : relation key
Equiv : Equivalence R
Eqdec : EqDec key R
Fset : FSet key Eqdec
z : key
c : A
l : list (key * A)
IHl : x `in` dom l -> exists b : A, binds x b l
Hin : z === x
?10768 == (Morphism (?10764 ==> flip impl) (eq (x, c)))
?10767 == (MorphismProxy ?10765 c)
?10766 == (Morphism (equiv ==> ?10765 ==> ?10764) pair)
?10765 == (relation A)
?10764 == (relation (key * A)).
I'm not sure what that means. Any pointers would be appreciated,
Edsko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
You really sent us very little context, but assuming you are using a defined equality because it is
more strictly more liberal than Leibniz equality (i.e. there are a and b such that a === b and a <> b),
I think that what you are trying to prove is not true! List.in explicitly relies on Leibniz equality.
Allowing what you want to perform would tantamount to proving z === x -> z = x.
List.in (x,c) ((z,c)::l) converts to (x,c) = (z,c) \/ (x,c) in l. Rewriting with Hin would require rewriting
inside a pair or inside an eq... These informations appear inside you error report.
If you want more, you need to give more details. What is behind the notation "_ === _"?
Yves
