- To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] "setoid rewrite failed"
- Date: Wed, 1 Apr 2009 12:38:40 +0100
Hi Yves,
You really sent us very little context, but assuming you are using a defined equality because it is
more strictly more liberal than Leibniz equality (i.e. there are a and b such that a === b and a <> b),
I think that what you are trying to prove is not true! List.in explicitly relies on Leibniz equality.
Aah, I see. That makes perfect sense, thank you.
(The === relation came from the Metatheory library bundled with Brian Aydemir's LNgen tool; quite frankly, I didn't really understand it and I was trying to copy the style of an existing lemma. "Proof by incantation" as my previous advisor would say ;)
Changing the relation R to be simply eq solves it.
Thanks,
Edsko
- [Coq-Club] "setoid rewrite failed", Edsko de Vries
- Re: [Coq-Club] "setoid rewrite failed",
Yves Bertot
- Re: [Coq-Club] "setoid rewrite failed", Edsko de Vries
- Re: [Coq-Club] "setoid rewrite failed", Pierre Letouzey
Yves Bertot
