- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: Yves Bertot <Yves.Bertot AT sophia.inria.fr>, coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] "setoid rewrite failed"
- Date: Wed, 1 Apr 2009 13:51:34 +0200
On Wed, Apr 01, 2009 at 12:38:40PM +0100, Edsko de Vries wrote:
> Hi Yves,
> >You really sent us very little context, but assuming you are using a
> >defined equality because it is
> >more strictly more liberal than Leibniz equality (i.e. there are a
> >and b such that a === b and a <> b),
> >I think that what you are trying to prove is not true! List.in
> >explicitly relies on Leibniz equality.
> Aah, I see. That makes perfect sense, thank you.
> (The === relation came from the Metatheory library bundled with Brian
> Aydemir's LNgen tool; quite frankly, I didn't really understand it and
> I was trying to copy the style of an existing lemma. "Proof by
> incantation" as my previous advisor would say ;)
> Changing the relation R to be simply eq solves it.
> Thanks,
> Edsko
By the way, there is now a file SetoidList.v in the standard library,
where you can find a definition for the fact of belonging to a list
modulo some setoid equality.
Best,
Pierre Letouzey
- [Coq-Club] "setoid rewrite failed", Edsko de Vries
- Re: [Coq-Club] "setoid rewrite failed",
Yves Bertot
Edsko de Vries
- Re: [Coq-Club] "setoid rewrite failed", Pierre Letouzey
Edsko de Vries
Yves Bertot
