- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Question on recursion
- Date: Tue, 21 Apr 2009 04:21:22 -0700 (PDT)
Hi everyone.
In the code that follows, I would like to substitute cheating with an object
(H: i<10). Function testing uses recursion as you can see. Therefore, this
object should be constructed recursively for every call. Is there a easy way
to do that?
Thanks in advance!
Variable cheating : forall (A : Type), A.
Implicit Arguments cheating [A].
Definition testing (P: forall i, i < 10 -> nat -> nat) : nat.
Proof.
intros.
refine ((fix check (i : nat) : nat :=
match i with
| 0 => 0
| S n => P n cheating (check n)
end) 5).
Qed.
Never say never.
View this message in context:
http://www.nabble.com/Question-on-recursion-tp23153959p23153959.html
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] Question on recursion, dimitrisg7
- Re: [Coq-Club] Question on recursion,
Adam Koprowski
dimitrisg7
Adam Koprowski
- Re: [Coq-Club] Question on recursion, Matthieu Sozeau
- Re: [Coq-Club] Question on recursion, Adam Chlipala
Adam Koprowski
dimitrisg7
Adam Koprowski
