- To: dimitrisg7 <dvekris AT hotmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Question on recursion
- Date: Tue, 21 Apr 2009 14:37:06 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=GBbXBkDA6dW02YlhgQkhVh/pT/QBTzSUECpvHVlvErucCmrSjyNU/OIz5nRQxwAdvd 99PPgAtFQeep8l3vvtI+ThK4tV+gnfOi+fpe/D7E/pDybVCFqoNjcfCW8T/kpZeD/SN2 fXxbvkLNsxIVRERO1TcMBKzsHOKRC9gLXjZFk=
You can easily define such function using the new Program feature (Coq >= 8.2):
Section testing.
Variable P : forall i, i < 10 -> nat -> nat.
Program Fixpoint check (i : nat) (H : i < 10) : nat :=
match i with
| 0 => 0
| S n => @P n _ (check n _)
end.
Next Obligation. Proof. auto with arith. Qed.
Program Definition testing := check 5 _.
End testing.
match i with
| 0 => 0
end.
End testing.
Cheers,
Adam
On Tue, Apr 21, 2009 at 13:21, dimitrisg7 <dvekris AT hotmail.com> wrote:
Hi everyone.
In the code that follows, I would like to substitute cheating with an object
(H: i<10). Function testing uses recursion as you can see. Therefore, this
object should be constructed recursively for every call. Is there a easy way
to do that?
Thanks in advance!
Variable cheating : forall (A : Type), A.
Implicit Arguments cheating [A].
Definition testing (P: forall i, i < 10 -> nat -> nat) : nat.
Proof.
intros.
refine ((fix check (i : nat) : nat :=
match i with
| 0 => 0
| S n => P n cheating (check n)
end) 5).
Qed.
Never say never.
View this message in context: http://www.nabble.com/Question-on-recursion-tp23153959p23153959.html
Sent from the Coq mailing list archive at Nabble.com.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Adam.Koprowski AT gmail.com, http://www.cs.ru.nl/~Adam.Koprowski
The difference between impossible and possible
lies in determination (Tommy Lasorda)
- [Coq-Club] Question on recursion, dimitrisg7
- Re: [Coq-Club] Question on recursion, Adam Koprowski
dimitrisg7
Adam Koprowski
- Re: [Coq-Club] Question on recursion, Matthieu Sozeau
- Re: [Coq-Club] Question on recursion, Adam Chlipala
Adam Koprowski
dimitrisg7
