coq-club - Re: [Coq-Club] Question on recursion
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Question on recursion
  • Date: Tue, 21 Apr 2009 09:31:21 -0400
Adam Koprowski wrote:
Sure, you can do the same thing without Program, but it gets slightly more complicated as you need to manually get the equality for the pattern-matched variable:
Section testing.
Variable P : forall i, i < 10 -> nat -> nat.
Definition check (i : nat) (H : i < 10) : nat.
Proof.
  refine (fix check (i : nat) (H : i < 10) {struct i} : nat :=
    match i as j return i = j -> nat with
    | 0 => fun _ => 0
    | S n => fun ij => P n _ (check n _)
    end refl); subst; auto with arith.
Defined.
End testing.
You can usually avoid introducing intermediate equality proofs by pushing arguments later in a function definition, like this:
Require Import Arith.
Section testing.
 Proof.
   refine (fix check (i : nat) : i < 10 -> nat :=
     match i return i < 10 -> _ with
       | 0 => fun _ => 0
       | S n => fun _ => P n _ (check n _)
     end); auto with arith.
 Defined.
End testing.
