- To: Matej Kosik <kosik AT fiit.stuba.sk>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How can I make this reasoning step in Coq ?
- Date: Thu, 23 Apr 2009 13:12:14 +0100
Matej Kosik wrote:
In Coq, it is possible to make the following reasoning steps:
E |- ~p
E, p |- False
with the `intro' tactics. Both that lines above are meant to be
"sequents" where |- separates the antecedent and the succedent.
With what tactics can I perform the following reasoning step:
E |- p
E, ~p |- False
(I am new to Coq.)
If I understand you right, the goal of your rule is on top and the supporting reason is on the bottom.
In that case, the latter step is a classical, rather than intuitionistic, inference, and so is not supported by default in Coq. You can get this sort of reasoning by importing the Classical module. This assumes the classical law of excluded middle, P \/ ~P, and derives other classical lemmas, which you can find in the standard library (for example, in Classical_Prop).
However, it may well be better to redesign your assumptions so that you don't have to go via ~~P. It is rarely simpler, let alone clearer, to find contradiction in a hypothesis ~P than to prove P directly.
HTH,
Ezra
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
- [Coq-Club] How can I make this reasoning step in Coq ?, Matej Kosik
- Re: [Coq-Club] How can I make this reasoning step in Coq ?,
Edsko de Vries
- Re: [Coq-Club] How can I make this reasoning step in Coq ?, Yves Bertot
Matej Kosik
Edsko de Vries
Matej Kosik
- Re: [Coq-Club] How can I make this reasoning step in Coq ?, Tillmann Rendel
Matej Kosik
Edsko de Vries
- Re: [Coq-Club] How can I make this reasoning step in Coq ?, Ezra Cooper
Edsko de Vries
