coq-club - Re: [Coq-Club] How can I make this reasoning step in Coq ?
chronological Thread
  • To: Edsko de Vries <Edsko.de.Vries AT cs.tcd.ie>
  • Cc: Matej Kosik <kosik AT fiit.stuba.sk>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] How can I make this reasoning step in Coq ?
  • Date: Thu, 23 Apr 2009 14:17:37 +0200
I believe Edsko misunderstood Matej's question. The problem is not to prove.
forall (E p : Prop) (E -> p) -> (E -> ~p -> False)
Rather the problem is to prove :
forall (E p : Prop) (E -> ~p -> False) -> E -> p
The question was " how do you get from a goal of the following shape:
p
To a goal of the following shape:
H' : ~p
False
If my interpretation of the question is right, then here is an answer:
By default, the Coq system lets you reason in a logical system that does not allow this step. There is a well-known distinction between two variants of logic, where one, called "intuitionistic logic" does not allow this kind of reasoning. There are advantages to restricting logic in this manner, and it appears that a lot of mathematics or computer science can still be done and reasoned about in this kind of restricted logic. If you work in this restricted logic, then there is no way to do what you want.
Now, if you don't want the restriction, you should load a logic complement, called "classical logic".
Require Import Classical.
Now, the step you want to perform can be done using the theorem NNPP, as in :
apply NNPP; intros <some hypothesis name>.
I hope this helps,
Yves
Edsko de Vries wrote:
Hi,
In Coq, it is possible to make the following reasoning steps:
       E |- ~p
    E, p |- False
with the `intro' tactics. Both that lines above are meant to be
"sequents" where |- separates the antecedent and the succedent.
With what tactics can I perform the following reasoning step:
        E |- p
    E, ~p |- False
Remember that ~ is a function (~p is syntactic sugar for p -> False). Hence, you can do this reasoning step as follows:
Variable E p : Prop.
Lemma foo : (E -> p) -> (E /\ ~p -> False).
Proof.
  intros H1 H2.
  destruct H2 as (e, not_p).
  apply not_p.
  apply H1.
  apply e.
Qed.
Edsko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
