coq-club - Re: [Coq-Club] Question about guardedness in CoFixpoint
chronological Thread
  • To: Edsko de Vries <Edsko.de.Vries AT cs.tcd.ie>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Question about guardedness in CoFixpoint
  • Date: Sun, 26 Apr 2009 16:59:40 -0400 (EDT)
Maybe not what you want, but I can define map2 after a CPS transform:
Definition stream' (A : Set) : Type :=
 forall C:Type,C -> (A -> stream A -> C) -> C.
Definition fromStream (A : Set) (xs : stream A) : stream' A :=
fun C c f =>
 match xs with
 | nil => c
 | cons x xs' => f x xs'
 end.
Definition toStream (A : Set) (xs : stream' A) : stream A :=
xs _ (nil A) (@cons _).
Definition map' (A B : Set) (f : A -> B)
(rec : (A -> B) -> stream A -> stream B)
(xs : stream' A) : stream' B :=
fun C c g => (xs C c (fun x xs' => g (f x) (rec f xs'))).
CoFixpoint map2 (A B : Set) (f : A -> B) (xs : stream A) : stream B :=
toStream (map' f (@map2 A B) (fromStream xs)).
On Sun, 26 Apr 2009, Edsko de Vries wrote:
Hi,
I have a question about guardedness checking in cofixpoint definitions.
I have simplified my problem as much as I could; hopefully, I have not
simplified it too much (you can copy and paste this email into Coq).
Given the definition of a stream, we can easily write a map function:
 Set Implicit Arguments.
 CoInductive stream (A : Set) : Set :=
   | nil : stream A
   | cons : A -> stream A -> stream A.
 CoFixpoint map (A B : Set) (f : A -> B) (xs : stream A) : stream B :=
   match xs with
   | nil => nil B
   | cons x xs' => cons (f x) (map f xs')
   end.
But now suppose that we want to write this map function in a different
way (the "why" is complicated, and I'd have to give a *lot* more
background): we will construct a type stream', which is basically the
top-level decomposition of a stream:
 Definition stream' (A : Set) : Set := (unit + A * stream A)%type.
   match xs with
   | nil => inl _ tt
   | cons x xs' => inr _ (x, xs')
   end.
   match xs with
   | inl _ => nil A
   | inr (x, xs') => cons x xs'
   end.
We now define a non-recursive function across stream', which leaves the
recursion to a different function, which it is passed as an argument:
   match xs with
   | inl u => inl _ u
   | inr (x, xs') => inr _ (f x, rec f xs')
   end.
Finally, we want to define the recursive map (say, map2) in terms of
map'; obviously, the function 'rec' that map' needs is map2 itself:
Unfortunately, this definition is not accepted by Coq:
 Error:
 Recursive definition of map2 is ill-formed.
 In environment
 map2 : forall A B : Set, (A -> B) -> stream A -> stream B
 A : Set
 B : Set
 f : A -> B
 xs : stream A
 Recursive call in the argument of cases in
 "match
    match
      match xs with
      | nil => inl (A * stream A) tt
      | cons x xs' => inr unit (x, xs')
      end
    with
    | inl u => inl (B * stream B) u
    | inr (pair x xs') => inr unit (f x, map2 A B f xs')
    end
  with
  | inl _ => nil B
  | inr (pair x xs') => cons x xs'
  end".
This is very unfortunate: I presume that Coq rejects this definition
because the recursive call to 'map2' is not guarded by 'cons'. However,
when you look at this definition a little longer, it becomes obvious
that the recursive call *is* in fact guarded: the recursive call only
occurs as part of
which will only match with the second part of the outermost match, and
therefore simplify to
 cons (f x) (map2 A B f xs')
which is exactly the recursive call that we made in the simple
definition of map, above.
Is there a way that we can convince Coq that this definition is in fact
ok? (Without modifying map')?
That would *really* be a big help :) No, *really* :)
Thanks,
Edsko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
