coq-club - Re: [Coq-Club] Question about guardedness in CoFixpoint
chronological Thread
  • To: Bruno Barras <bruno.barras AT inria.fr>
  • Cc: Edsko de Vries <Edsko.de.Vries AT cs.tcd.ie>, Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Question about guardedness in CoFixpoint
  • Date: Sun, 26 Apr 2009 19:06:59 -0400 (EDT)
On Sun, 26 Apr 2009, Bruno Barras wrote:
Hi,
Just 2 little remarks. Firstly, you don't have to go that far in the CPS transformation, by adding the continuation only to map' (and not in the stream' type). The most noticeable change w.r.t. Edsko's code is the type of map':
Definition map' (A B : Set) (f : A -> B) (rec : (A -> B) -> stream A -> stream B)
    (xs : stream' A) (C:Type) (K : stream' B -> C) : C :=
  match xs with
  | inl u => K (inl _ u)
  | inr (x, xs') => K (inr _ (f x, rec f xs'))
  end.
CoFixpoint map2 (A B : Set) (f : A -> B) (xs : stream A) : stream B :=
  map' f (@map2 A B) (fromStream xs) toStream.
(I haven't checked the example, but if it fails to type-check, this can be fixed easily.)
I just checked and it works. The key is that you put the continuation K into each branch of the match statement. Very clever. I'll try to remember this trick.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
