- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Question about guardedness in CoFixpoint
- Date: Sun, 26 Apr 2009 20:46:08 +0100
Hi,
I have a question about guardedness checking in cofixpoint definitions.
I have simplified my problem as much as I could; hopefully, I have not
simplified it too much (you can copy and paste this email into Coq).
Given the definition of a stream, we can easily write a map function:
Set Implicit Arguments.
CoInductive stream (A : Set) : Set :=
| nil : stream A
| cons : A -> stream A -> stream A.
CoFixpoint map (A B : Set) (f : A -> B) (xs : stream A) : stream B :=
match xs with
| nil => nil B
| cons x xs' => cons (f x) (map f xs')
end.
But now suppose that we want to write this map function in a different
way (the "why" is complicated, and I'd have to give a *lot* more
background): we will construct a type stream', which is basically the
top-level decomposition of a stream:
Definition stream' (A : Set) : Set := (unit + A * stream A)%type.
Definition fromStream (A : Set) (xs : stream A) : stream' A :=
match xs with
| nil => inl _ tt
| cons x xs' => inr _ (x, xs')
end.
Definition toStream (A : Set) (xs : stream' A) : stream A :=
match xs with
| inl _ => nil A
| inr (x, xs') => cons x xs'
end.
We now define a non-recursive function across stream', which leaves the
recursion to a different function, which it is passed as an argument:
Definition map' (A B : Set) (f : A -> B)
(rec : (A -> B) -> stream A -> stream B)
(xs : stream' A) : stream' B :=
match xs with
| inl u => inl _ u
| inr (x, xs') => inr _ (f x, rec f xs')
end.
Finally, we want to define the recursive map (say, map2) in terms of
map'; obviously, the function 'rec' that map' needs is map2 itself:
CoFixpoint map2 (A B : Set) (f : A -> B) (xs : stream A) : stream B :=
toStream (map' f (@map2 A B) (fromStream xs)).
Unfortunately, this definition is not accepted by Coq:
Error:
Recursive definition of map2 is ill-formed.
In environment
map2 : forall A B : Set, (A -> B) -> stream A -> stream B
A : Set
B : Set
f : A -> B
xs : stream A
Recursive call in the argument of cases in
"match
match
match xs with
| nil => inl (A * stream A) tt
| cons x xs' => inr unit (x, xs')
end
with
| inl u => inl (B * stream B) u
| inr (pair x xs') => inr unit (f x, map2 A B f xs')
end
with
| inl _ => nil B
| inr (pair x xs') => cons x xs'
end".
This is very unfortunate: I presume that Coq rejects this definition
because the recursive call to 'map2' is not guarded by 'cons'. However,
when you look at this definition a little longer, it becomes obvious
that the recursive call *is* in fact guarded: the recursive call only
occurs as part of
which will only match with the second part of the outermost match, and
therefore simplify to
cons (f x) (map2 A B f xs')
which is exactly the recursive call that we made in the simple
definition of map, above.
Is there a way that we can convince Coq that this definition is in fact
ok? (Without modifying map')?
That would *really* be a big help :) No, *really* :)
Thanks,
Edsko
- [Coq-Club] Question about guardedness in CoFixpoint, Edsko de Vries
