coq-club - Re: [Coq-Club] CoInductive Type Instantiation
chronological Thread
  • To: Cedric Auger <Cedric.Auger AT lri.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] CoInductive Type Instantiation
  • Date: Wed, 29 Jul 2009 21:31:21 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=bYbuoiuyIjEww1gvVe9TXfr4LdN947U80uPHKBbId4KsVHK5EBP4PQsUqULHGel+qS V+6tQXZHHeUzYvSGZe03I2Nechvuu8pQzRRysgIYr9lGSTM4jsNWccOppbikuaAUAFKo uFj0VbvoGdUG9CiMLOaAAJsV4I/IQYWGu140I=
The CoFixpoint operator seems to work.
On Wed, Jul 29, 2009 at 7:46 PM, Cedric Auger <Cedric.Auger AT lri.fr> wrote:
Coq User a écrit :
In the (very simplified) example below some coinductive types are defined for a Parent and Child relationship.  How can a Parent or Child be instantiated since they both co-refer to each other?  Can it be done as in object oriented programming where a Parent would be defined with a 'null' child first and similarly the Child be defined with 'null' and later the fields be updated to refer to each other?  How?
Require Import String.
CoInductive Parent:Set :=
| Build_Parent (fatherOrMother:string)(child:Child)
with
Child:Set :=
| Build_Child (father:Parent)(mother:Parent).
(*Functions for Parent fields.*)
Definition fatherOrMother:Parent -> string :=                   (fun p:Parent =>
        match p with
        | (Build_Parent fm ch) => fm
        end).
Definition child:Parent -> Child :=                   (fun p:Parent =>
        match p with
        | (Build_Parent fm ch) => ch
        end).
(*Functions for Child*)
Definition father:Child -> Parent :=                   (fun p:Child =>
        match p with
        | (Build_Child f m) => f
        end).
Definition mother:Child -> Parent :=                   (fun p:Child =>
        match p with
        | (Build_Child f m) => m
        end).
(*Instantiate a Parent*)
Definition father:Parent := Build_Parent "father"
  (Build_Child ( (*Father ??? How to refer to the same father Instance being defined here???*)) ((*Mother*)))
(*Same problem if we try to instantiate the Child first.*)
Here is a solution, but it will probably be a pain in the neck to use it.
CoFixpoint father2 : Parent :=
 Build_Parent "father" (Build_Child father2 mother2)
with mother2 : Parent :=
 Build_Parent "mother" (Build_Child father2 mother2).
Forget OOprogramming in Coq, and above all forget those tricks, you are in a purely functionnal language you CANNOT do side effects,
you can define Monads as in Haskell, or "emulate" the memory with a list (or a map), which is probably a bad idea, for example
have a positive map:
parents:
1 -> ("father", 1)
10 ->  ("mother", 1)
childs:
 1 -> (1, 10)
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
