- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] CoInductive Type Instantiation
- Date: Tue, 28 Jul 2009 14:31:44 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=x3+vOM2l/zR9yAGFCF6g9pCWc0OrZ4ECPN0Hr9z2Md+5Vj77B2z7aQgrn5KrDS/RA3Nh+zco7saqoQZyWALkcAYlRWLZ8bJvTywaEhLb52bdaUNtxeavKqCyZubi1/FmsBcOll4sIiD1RHExWvvKTW24s8pKjDNj5T1fEpZVjHs=;
In the (very simplified) example below some coinductive types are defined for a Parent and Child relationship. How can a Parent or Child be instantiated since they both co-refer to each other? Can it be done as in object oriented programming where a Parent would be defined with a 'null' child first and similarly the Child be defined with 'null' and later the fields be updated to refer to each other? How?
Require Import String.
CoInductive Parent:Set :=
| Build_Parent (fatherOrMother:string)(child:Child)
with
Child:Set :=
| Build_Child (father:Parent)(mother:Parent).
(*Functions for Parent fields.*)
Definition fatherOrMother:Parent -> string :=
(fun p:Parent =>
match p with
| (Build_Parent fm ch) => fm
end).
Definition child:Parent -> Child :=
(fun p:Parent =>
match p with
| (Build_Parent fm ch) => ch
end).
(*Functions for Child*)
Definition father:Child -> Parent :=
(fun p:Child =>
match p with
| (Build_Child f m) => f
end).
Definition mother:Child -> Parent :=
(fun p:Child =>
match p with
| (Build_Child f m) => m
end).
(*Instantiate a Parent*)
Definition father:Parent := Build_Parent "father"
(Build_Child ( (*Father ??? How to refer to the same father Instance being defined here???*)) ((*Mother*)))
(*Same problem if we try to instantiate the Child first.*)
with
Child:Set :=
(fun p:Parent =>
match p with
end).
(fun p:Parent =>
match p with
end).
(fun p:Child =>
match p with
end).
(fun p:Child =>
match p with
end).
- [Coq-Club] CoInductive Type Instantiation, CoqUser CoqUser
- <Possible follow-ups>
Coq User
- Re: [Coq-Club] CoInductive Type Instantiation, Cedric Auger
