coq-club - [Coq-Club] CoInductive Type Instantiation
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] CoInductive Type Instantiation
  • Date: Wed, 29 Jul 2009 07:45:46 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type; b=mnkxLFSxbjCB5/AUCq5bzN0tEEg3Ko6LL2AwDwW1YICiFyOCGksHncp8ehMIi47Sj9kyhMBuHajYR3uZ5QNUQgD4F/1ESUWqkJIamqs/tyc2wK7QBwlNWyi7+G0WoEGXwfJpJzBtdDR+znEQLjnTIEsF3NKk08c3mkRCOAGvWcI=;
In the (very simplified) example below some coinductive types are defined for a Parent and Child relationship.  How can a Parent or Child be instantiated since they both co-refer to each other?  Can it be done as in object oriented programming where a Parent would be defined with a 'null' child first and similarly the Child be defined with 'null' and later the fields be updated to refer to each other?  How?
Require Import String.
CoInductive Parent:Set :=
| Build_Parent (fatherOrMother:string)(child:Child)
with
Child:Set :=
| Build_Child (father:Parent)(mother:Parent).
(*Functions for Parent fields.*)
Definition fatherOrMother:Parent -> string :=
     (fun p:Parent =>
         match p with
         | (Build_Parent fm ch) => fm
         end).
Definition child:Parent -> Child :=
     (fun p:Parent =>
         match p with
         | (Build_Parent fm ch) => ch
         end).
(*Functions for Child*)
Definition father:Child -> Parent :=
     (fun p:Child =>
         match p with
         | (Build_Child f m) => f
         end).
Definition mother:Child -> Parent :=
     (fun p:Child =>
         match p with
         | (Build_Child f m) => m
         end).
(*Instantiate a Parent*)
Definition father:Parent := Build_Parent "father"
   (Build_Child ( (*Father ??? How to refer to the same father Instance being defined here???*)) ((*Mother*)))
(*Same problem if we try to instantiate the Child first.*)
