- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Strengthening the definitional equality on types?
- Date: Wed, 05 Aug 2009 12:47:56 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:cc:subject:references :in-reply-to:content-type:content-transfer-encoding; b=wX56GDRuxDeEsJsSx3NHQPTIxZK6CKwAFBhdMeltA7Bj3hFFt0tyw8tF78mKtIG+Af XrL6hVBnrwqJ0PpNmwGicfTIBzmYxkLvJSkNYDeghVaXMgnef9JJoESWbiO7F+JY3qgL b/er4UOF0Lfifqb5tvow9MI3y7RAq4NDvQubE=
What about the following code?
+ it type checks
+ it is semantically exactly what you wanted
+ it has same signature for parameters
- it is awful when unfolding/defining
- it implies destruction on d to get the equality (even if it is more convenient to type:
destruct d; apply isoAx
than
destruct d; [apply isoAxL | apply isoAxR]
, it is less convenient than typing
apply isoAxL)
Module Type Iso.
Parameter S : Dir -> Set.
Parameter f : forall d, S d -> S (swap d).
Axiom isoAx : forall d x, match d as d0 return S (swap (swap d0)) -> S d0 -> Prop with
| R => fun x y => x = y
| L => fun x y => x = y
end (f (swap d) (f d x)) x.
End Iso.
or this code:
+ it type checks
- it is awful to cast whenever required
Module Type Iso.
Definition cast : forall d, S (swap (swap d)) -> S d :=
fun d => match d as d0 returns S (swap (swap d0)) -> S d0 with
| L => fun x => x
| R => fun x => x
end.(* identity type-casted *)
Axiom isoAx : forall d x, cast _ (f (swap d) (f d x)) = x.
End Iso.
Benjamin Pierce wrote:
Suppose one wanted to define isomorphisms in the following slightly unusual fashion:
Inductive Dir : Set := R | L.
Definition swap (d:Dir) := match d with R => L | L => R end.
Module Type Iso.
Axiom isoAx : forall d x, f (swap d) (f d x) = x.
End Iso.
Instead of two separate functions, two axioms, and two sets, we index everything by a direction. This means we can write definitions of composition of isomorphisms, juxtaposition, etc. and prove their properties very compactly (saving 50% of the typing each time).
Unfortunately, this definition doesn't typecheck: the term
f (swap d) (f d x)
has type S (swap (swap d)), not S d, which is the type of x. Of course, swap (swap d) is provably equal to d for every d, but not convertible.
What to do? We've seen the discussion of John Major equality in CoqArt... is this our only hope, or is there a lighter way?
Thanks!
- Benjamin Pierce and Martin Hofmann
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Strengthening the definitional equality on types?, Benjamin Pierce
- Re: [Coq-Club] Strengthening the definitional equality on types?, Adam Chlipala
- Re: [Coq-Club] Strengthening the definitional equality on types?, Arnaud Spiwack
- Re: [Coq-Club] Strengthening the definitional equality on types?, AUGER Cedric
- Re: [Coq-Club] Strengthening the definitional equality on types?, Stefan Monnier
- Re: [Coq-Club] Strengthening the definitional equality on types?, Conor McBride
- Re: [Coq-Club] Strengthening the definitional equality on types?, Hugo Herbelin
