coq-club - Re: [Coq-Club] Strengthening the definitional equality on types?
chronological Thread
  • From: Conor McBride <conor AT strictlypositive.org>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Strengthening the definitional equality on types?
  • Date: Thu, 6 Aug 2009 11:34:12 +0100
Hi
Meanwhile, when it comes to tinkering with the definitional
equality...
...be careful what you wish for.
On 5 Aug 2009, at 19:29, muad wrote:
Stefan Monnier wrote:
What to do?  We've seen the discussion of John Major equality in
CoqArt... is this our only hope, or is there a lighter way?
I see other people have already solved your problem, but to get back to
the title of your email, I also wonder: wouldn't it be possible to
strengthen the definitional equality so that your code is accepted
as is.
It seems that what is required here is to extend CIC with the an η- rule
for inductive definitions plus some kind of "match-associativity"
(analogous to the let-associativity rule that says that
let x₁ = let x₂ = e₁ in e₂ in e₃ ≡ let x₂ = e₁ in let x₁ = e₂ in e₃
assuming x₂∉fv(e₁)).
I.e.:
    swap (swap d)
≡ match (match d with R => L | L => R end) with R => L | L => R end
    ≡ match d with R => match L with R => L | L => R end
                 | L => match R with R => L | L => R end
      end
    ≡ match d with R => R | L => L end
    ≡ d
the first ≡ is by unfolding the definition, the second is by
match-associativity, the third by the usual reduction rules, the fourth
by η.
Since CIC's consistency is not broken by η applied to the function
space, maybe it can also sustain η applied to the inductive
definitions space (tho you'd probably get into trouble with the issue
of the strong elimination of large inductive definitions).
OTOH, adding a form of match-associativity seems a lot more
far-fetched :-(
Too bad, because it would be handy in various circumstances.
It seems difficult to do this for inductive datatypes in general.
Somebody must know the status of eta-rules, commuting conversions,
and such like..? How badly do they break the decidability of
definitional equality? What happens with inductive families?
Just because it's vaguely related (to your η idea) and also interesting,
there is a paper about simply typed calculus with eta for 2 (aka bool or
Dir), http://www.cs.nott.ac.uk/~txa/publ/flops04.pdf
In that calculus the definitional equality f = f . f . f (and swap . swap =
id) holds, so now I wonder how to go about extending this to a full blown
dependent type theory?
Yeah, it's cute. It amounts to comparing the BDDs which express
the extensions of functions, if I recall correctly.
The general idea seems to be to improve the definitional equality
for functions from the precisely intensional by sampling them on
a finite covering of their inputs: picking the trivial covering
consisting of a fresh variable gives you the usual eta-law for
function spaces, but one could imagine constructing coverings
on a per-type basis. It would take some care to get this right,
in a suitably higher-order way. There's also a limitation with
empty types: extensionally, there's only one function in 0 -> 2,
but you may perfectly well give that type to (fun _ => true) and
(fun _ => false), and if you choose to identify them
definitionally, you collapse the definitional equality in nonempty
contexts.
Meanwhile, if we want to solve this particular problem,
not . not = id, by adjusting the definitional equality, there's
perhaps a cheap way. Suppose we have a primitive not, with
computation rules
  not true  --> false
  not false --> true
(defining not as a match does not break this trick but it increases
its price, unless you do the "labelled type" thing I wrote about
a while back). Suppose also that your conversion test is in two
phases: first, untyped beta-delta-iota reduction; second,
type-directed expansion to eta-long form. Modify the second
phase to simplify neutral terms of ground type, rewriting
(not (not n)) to n. Note that this n is necessarily neutral, hence
this simplification can never create a redex. It is easy to show
that extending the equational theory with (not (not n)) = n for
neutral n does, in fact, make (not (not t)) = t hold for any t.
This gives me some hope that the above procedure is complete to
decide the theory so extended, but to prove this conjecture is a
harder task, and I have not yet done so.
There's work to do here, but I think this may be yet another
Jagger/Richards situation, where you can't have the grand theory
extension of which the problem is a tiny special case, but you
can still solve the problem.
All the best
Conor
