- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Mixing induction and coinduction
- Date: Wed, 26 Aug 2009 19:04:43 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=hjZn8TruP7kLzZKdmIDSD/HqdYZ5yUzvkomcu+U4PQxg/TaKTec3kbUch5FvXtB16A drARYFADANy/ZbBV5RSZrjRUO7L2JhOzIpKWyRWjexdhWySP/zlVBeTuxERoqdotPlXc jN3Fgof8VAeNPwxWGM4gKJw5ZdfhmdfAw6+m4=
Hi,
This is related to my previous question, but a lot simpler (hopefully I didn't simplify the problem too much). I don't understand how to
mix induction and coinduction in Coq. Here is a *very* simple example:
Require Import List.
CoInductive T : Set :=
| A : T -> T
| B : list T -> T.
CoFixpoint f (t : T) : T :=
match t with
| A t1' => A (f t1')
| B t1s => B (map f t1s)
end.
This definition of [f] seems ok to me, but is rejected as not guarded because the recursive argument appears as argument to a function (in this case, map). How should one define functions and data types like this? (I don't care if I have to redefine list; I'm only using list as an example -- the loss of the use of library functions is not an issue.)
Thanks,
Edsko
PS. I seem to recall that a question like this came up before, but I can't find it.
- [Coq-Club] Mixing induction and coinduction, Edsko de Vries
- Re: [Coq-Club] Mixing induction and coinduction,
Ekaterina Komendantskaya
- Re: [Coq-Club] Mixing induction and coinduction, Nils Anders Danielsson
- Re: [Coq-Club] Mixing induction and coinduction, Celia Picard
