- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mixing induction and coinduction
- Date: Thu, 27 Aug 2009 16:54:11 +0200
Hi,
I am a PhD student in Toulouse, doing my research with Ralph Matthes.
I have spent the last months trying to solve a problem very similar to the one presented in this thread.
We have come up with a solution. I have extracted here only the elements needed to solve this particular example.
Set Implicit Arguments.
(* First of all, I need a finite set of elements.
I use the well-known definition of Fin by Mc Bride & Mc Kinna *)
Inductive Fin: nat -> Set :=
first k : Fin (S k)
| succ k: Fin k -> Fin (S k).
(* By the way, we have a proof of injectivity of Fin that looks a bit complicated.
Is there a well-known (easier) proof of Fin n = Fin m -> n = m ? *)
(* Then I define a function from that finite set to the types of elements we want*)
Definition ilistn (T: Set) (n:nat) := Fin n -> T.
(* And I finally define a tuple made of this function and the
cardinality of its definition set *)
Definition ilist(T:Set) := {n:nat & ilistn T n}.
(* These 2 functions are just redefinition of projections on ilist*)
Definition lgti(T: Set)(i: ilist T): nat:= projS1 i.
Definition fcti(T: Set)(i: ilist T): ilistn T (lgti i) := projT2 i.
(* Last thing needed for this example is an equivalent for map.
On ilists, it actually corresponds to a composition of functions. *)
Definition imap(T U:Set) (f:T->U) (l:ilist T): ilist U :=
existS (ilistn U) (lgti l) (fun i => f (fcti l i)).
(* Finally, I can define T and f *)
CoInductive T: Set :=
| A : T -> T
| B : ilist T -> T.
CoFixpoint f (t : T) : T :=
match t with
| A t1' => A (f t1')
| B t1s => B (imap f t1s)
end.
I hope this will help, although it can only solve problems of mixed induction and co-induction dealing with lists.
Best,
Celia
Edsko de Vries wrote:
Hi,
This is related to my previous question, but a lot simpler (hopefully I didn't simplify the problem too much). I don't understand how to
mix induction and coinduction in Coq. Here is a *very* simple example:
Require Import List.
CoInductive T : Set :=
| A : T -> T
| B : list T -> T.
match t with
| A t1' => A (f t1')
| B t1s => B (map f t1s)
end.
This definition of [f] seems ok to me, but is rejected as not guarded because the recursive argument appears as argument to a function (in this case, map). How should one define functions and data types like this? (I don't care if I have to redefine list; I'm only using list as an example -- the loss of the use of library functions is not an issue.)
Thanks,
Edsko
PS. I seem to recall that a question like this came up before, but I can't find it.
- [Coq-Club] Mixing induction and coinduction, Edsko de Vries
- Re: [Coq-Club] Mixing induction and coinduction,
Ekaterina Komendantskaya
- Re: [Coq-Club] Mixing induction and coinduction, Nils Anders Danielsson
- Re: [Coq-Club] Mixing induction and coinduction, Celia Picard
