- From: Ekaterina Komendantskaya <komendantskaya AT gmail.com>
- To: Edsko de Vries <edskodevries AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Mixing induction and coinduction
- Date: Wed, 26 Aug 2009 22:23:24 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=xs+IXMCfIxn1QRThAfgIc9vUUNqM0WNHYL0rphbCuXqGSMNgreJxhfYfCusKhIB+0k JpT59ID19fCpTqzhskGBrN3Zlb/C4VUqtJ5CPQq/HvqZwoA7pL4cvWB119rHmbs+RI+g Z6dcvIojGQ4tiXdYBVN4nBKGKXPbdHl/P5mpA=
Hi,
Yves Bertot and myself had a paper about it in the proceedings of
TYPES'08, and we also gave references to other approaches (there are
quite a few).
The paper is available here:
http://hal.inria.fr/inria-00322331/en/
The paper dealt in particular with non-guarded corecursive definitions
containing "map", like in your example.
A related discussion in this mailing list was under the topic
[Coq-Club] Codata: problem with guardedness condition?
And in particular, there was given a nice link to a similar discussion
at Nottingham FP lunch:
http://sneezy.cs.nott.ac.uk/fplunch/weblog/?p=109
Perhaps some of this has already been published...
Best,
Ekaterina
2009/8/26 Edsko de Vries
<edskodevries AT gmail.com>:
> Hi,
> This is related to my previous question, but a lot simpler (hopefully I
> didn't simplify the problem too much). I don't understand how to
> mix induction and coinduction in Coq. Here is a *very* simple example:
> Require Import List.
> CoInductive T : Set :=
> | A : T -> T
> | B : list T -> T.
> CoFixpoint f (t : T) : T :=
> match t with
> | A t1' => A (f t1')
> | B t1s => B (map f t1s)
> end.
> This definition of [f] seems ok to me, but is rejected as not guarded
> because the recursive argument appears as argument to a function (in this
> case, map). How should one define functions and data types like this? (I
> don't care if I have to redefine list; I'm only using list as an example --
> the loss of the use of library functions is not an issue.)
> Thanks,
> Edsko
> PS. I seem to recall that a question like this came up before, but I can't
> find it.
School of Computer Science
University of St Andrews
St Andrews,
KY16 9SX, UK
Tel. 01334 463238
- [Coq-Club] Mixing induction and coinduction, Edsko de Vries
- Re: [Coq-Club] Mixing induction and coinduction, Ekaterina Komendantskaya
- Re: [Coq-Club] Mixing induction and coinduction, Nils Anders Danielsson
- Re: [Coq-Club] Mixing induction and coinduction, Celia Picard
