coq-club - [Coq-Club] "suppose it is ... with" in C-zar
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] "suppose it is ... with" in C-zar
  • Date: Thu, 22 Oct 2009 01:04:34 +0300
Hello.
I'm using Coq 8.2pl1. Occasionally when trying to do induction in
C-zar, a "suppose it is" -instruction yields the error:
Error: Wrong number of extra arguments: 1expected.
From quick perusing of the sources, it seems that these "extra
arguments" are something that are supposed to be given in a
"with"-clause after the case pattern. However, its usage doesn't seem
to be documented anywhere, and in fact trying to use "with" gives a
syntax error (which is mysterious, since I can see that it has been
included in the grammar in g_decl_mode.ml4).
Could someone shed light on the nature of the error message and the
intended use of the with-clause? Thanks.
Lauri
