- To: Yves Bertot <Yves.Bertot AT sophia.inria.fr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] More nested fixpoint difficulties.
- Date: Sun, 25 Oct 2009 11:45:31 -0400 (EDT)
On Sun, 25 Oct 2009, Yves Bertot wrote:
Having only one principal argument for guarded recursion is not the problem, I believe. In my opinion, the problem is that when analyzing an internal fix construct, only the principal argument is used to pass legitimate guarded variables to the body of the fix construct. This can be seen in Coq sources, file kernel/inductive.ml
It is beyond my competence to change this file and be sure that it does not break consistency.
Thanks for looking at this. I suspected that was the problem, but it is hard or impossible to find a description of the guardedness
specification.
concerning Russell's initial problem, it is possible to workaround it, by collecting the values of recursive calls on the second list in a first pass, putting them in a list, and retrieving them during the second recursive traversal.
This may be unsatisfactory for efficiency reasons, but I believe it works. Here is my proposal.
Thanks for this. I was beginning to think of something along these lines, but I hadn't worked out the details yet.
In my actual problem I found a way of eliminating the recursive call to elements of my second list by using information that can be found in the first list. However this solution is really specific to my actual problem and won't work in general like your solution does.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] Meta theory: induction over terms with abstract variables, Robbert Krebbers
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Adam Chlipala
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Brian E. Aydemir
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Hugo Herbelin
- [Coq-Club] More nested fixpoint difficulties.,
roconnor
- Re: [Coq-Club] More nested fixpoint difficulties.,
Adam Chlipala
Yves Bertot
- Re: [Coq-Club] More nested fixpoint difficulties., roconnor
Yves Bertot
Adam Chlipala
