- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: roconnor AT theorem.ca, Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] More nested fixpoint difficulties.
- Date: Sun, 25 Oct 2009 16:11:11 +0100
Adam Chlipala wrote:
Having only one principal argument for guarded recursion is not the problem, I believe. In my opinion, the problem is that when analyzing an internal fix construct, only the principal argument is used to pass legitimate guarded variables to the body of the fix construct. This can be seen in Coq sources, file kernel/inductive.ml
It's not surprising that this fails. Even though you don't need to write a termination annotation in the definition of [Z], Coq infers one for you. It has to pick one or the other of the two arguments. Whichever one it picks, the matching call to [tree_ind0] isn't structurally recursive. I think this comes down to the fundamental limitation that [Fixpoint] needs a termination argument based on just a single input. You could perhaps get around this by changing [Z] to take a pair as input, possibly also switching to [Function] instead of [Fixpoint].
It is beyond my competence to change this file and be sure that it does not break consistency.
concerning Russell's initial problem, it is possible to workaround it, by collecting the values of recursive calls on the second list in a first pass, putting them in a list, and retrieving them during the second recursive traversal.
This may be unsatisfactory for efficiency reasons, but I believe it works. Here is my proposal.
Require Import List.
Inductive tree (A:Type) :=
node : A -> list (tree A) -> tree A.
Section Foo.
Variables (A:Type) (P : tree A -> Prop) (Q: list (tree A) -> list (tree A) -> Prop).
Hypotheses
(H:forall (a:A) (l m:list (tree A)), Q l m -> P (node A a l))
(H0: forall l, Q nil l)
(H0': forall l, Q l nil)
(H1: forall t, P t -> forall s, P s -> forall l m, Q l m -> Q (cons t l) (cons s m)).
Section Z.
Hypothesis (tree_ind0 : forall t, P t).
Fixpoint unqualify (l : list {x | P x}) :=
match l with nil => nil | a::tl => let (v, _) := a in v::unqualify tl end.
(* this function is easier to construct by proof. *)
Fixpoint Z1 (l : list (tree A)) : {l' | unqualify l' = l} :=
match l return {l' | unqualify l' = l} with
nil => exist (fun l' => unqualify l' = nil) nil (refl_equal _)
| x::tl => let (l1, h) := Z1 tl in
exist (fun l' => unqualify l' = x::tl)
(exist (fun x => P x) x (tree_ind0 x)::l1)
match h in _ = b return x::unqualify l1 = x::b with
refl_equal => refl_equal (x::unqualify l1)
end
end.
Fixpoint Z (l : list (tree A)) (m: list {x | P x}) : Q l (unqualify m) :=
match l return Q l (unqualify m) with
nil => H0 (unqualify m)
| t::l0 => match m return Q (t::l0) (unqualify m) with
nil => H0' (t::l0)
| (exist s' Ps')::m0 => H1 _ (tree_ind0 t) _ Ps' _ _ (Z l0 m0)
end
end.
End Z.
Fixpoint tree_ind0 (t:tree A) : P t :=
match t as x return P x with
| node a l =>
let (l', h) := Z1 tree_ind0 l in H a l (unqualify l') (Z tree_ind0 l l')
end.
End Foo.
- [Coq-Club] Meta theory: induction over terms with abstract variables, Robbert Krebbers
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Adam Chlipala
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Brian E. Aydemir
- Re: [Coq-Club] Meta theory: induction over terms with abstract variables, Hugo Herbelin
- [Coq-Club] More nested fixpoint difficulties.,
roconnor
- Re: [Coq-Club] More nested fixpoint difficulties.,
Adam Chlipala
- Re: [Coq-Club] More nested fixpoint difficulties., Yves Bertot
Adam Chlipala
