- To: Flávio Leonardo Cavalcanti de Moura <flaviomoura AT unb.br>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] matching
- Date: Tue, 01 Dec 2009 11:21:39 -0500
Flávio Leonardo Cavalcanti de Moura wrote:
I am stucked in the end of a proof because I need to 'evaluate' a
pattern matching.
[snip]
(fix ith_remainder (d : pair_t) (i0 : nat) {struct i0} : nat :=
match d with
| pair a0 b0 =>
if zerop b0
then 0
else
match i0 with
| 0 => mod a0 b0
| S n => mod b0 (ith_remainder (pair a0 b0) n)
end
end) (pair a b) (S i + 1)< ith_remainder (pair a b) (S i)
The key is in the [{struct i0}] annotation. This says that your function [ith_remainder] is defined as structurally recursive on the [i0] argument. Thus, a call to [ith_remainder] will only simplify when the top-level structure of the [i0] argument is known. In your example code, it is clear that this argument is greater than 0, but deducing this takes a little more smarts than Coq's computation rules will apply. If you manage to rewrite [S i + 1] into [S (S i)] (or any other term built directly from [S]), then you will see the reduction you are looking for.
Feel free to write again if it you need any help on how to perform this rewrite.
- [Coq-Club] matching, Flávio Leonardo Cavalcanti de Moura
- Re: [Coq-Club] matching, Adam Chlipala
- Re: [Coq-Club] matching, Flávio Leonardo Cavalcanti de Moura
Guillaume Melquiond
