coq-club - Re: [Coq-Club] matching
chronological Thread
  • From: Fl�vio Leonardo Cavalcanti de Moura <flaviomoura AT unb.br>
  • To: Adam Chlipala <adamc AT hcoop.net>
  • Cc: flaviomoura AT unb.br, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] matching
  • Date: Tue, 01 Dec 2009 15:24:04 -0200
Em Ter, 2009-12-01 Ã s 11:21 -0500, Adam Chlipala escreveu:
> Flávio Leonardo Cavalcanti de Moura wrote:
> > I am stucked in the end of a proof because I need to 'evaluate' a
> > pattern matching.
> > [snip]
> >     (fix ith_remainder (d : pair_t) (i0 : nat) {struct i0} : nat :=
> >        match d with
> >        | pair a0 b0 =>
> >            if zerop b0
> >            then 0
> >            else
> >             match i0 with
> >             | 0 =>  mod a0 b0
> >             | S n =>  mod b0 (ith_remainder (pair a0 b0) n)
> >             end
> >        end) (pair a b) (S i + 1)<  ith_remainder (pair a b) (S i)
> The key is in the [{struct i0}] annotation.  This says that your
> function [ith_remainder] is defined as structurally recursive on the
> [i0] argument.  Thus, a call to [ith_remainder] will only simplify when
> the top-level structure of the [i0] argument is known.  In your example
> code, it is clear that this argument is greater than 0, but deducing
> this takes a little more smarts than Coq's computation rules will
> apply.  If you manage to rewrite [S i + 1] into [S (S i)] (or any other
> term built directly from [S]), then you will see the reduction you are
> looking for.
> Feel free to write again if it you need any help on how to perform this
> rewrite.
Dear Adam,
        Thank you for the tip. I managed to complete the proof!
Cheers,
Flávio.
