- To: "Agda mailing list" <agda AT lists.chalmers.se>, <coq-club AT inria.fr>
- Subject: [Coq-Club] Agda with the excluded middle is inconsistent ?
- Date: Thu, 7 Jan 2010 00:59:14 +0100
Hi everyone,
I proved the absurdity in Agda assuming the
excluded middle.
Is it a well-known fact ?
It seems that Agda's set theory is
weird.
This comes from the injectivity of inductive type
constructors.
The proof sketch is as follows.
Define a family of inductive type
data I : (Set -> Set) ->
Set where
with no constructors.
By injectivity of type constructors, I can show
that I : (Set -> Set) -> Set is injective.
As you may see, there is a size problem with this
injectivity.
So, I just used the cantor's diagonalization to
derive absurdity in a classical way.
Does anyone know whether cantor's diagonalization
essentially needs the classical axiom, or can be done intuitionistically
If the latter is true, then the Agda system is
inconsistent.
Please have a look at the Agda code below, and let
me know if there's any mistakes.
All comments are wellcome.
Thanks,
Chung-Kil Hur
============== Agda code
module cantor where
data Empty : Set where
data One : Set where
one : One data coprod (A : Set1) (B : Set1) : Set1
where
inl : �� (a : A) -> coprod A B inr : �� (b : B) -> coprod A B postulate exmid : �� (A : Set1) -> coprod
A (A -> Empty)
data Eq1 {A : Set1} (x : A) : A -> Set1
where
refleq1 : Eq1 x x cast : �� { A B } -> Eq1 A B -> A ->
B
cast refleq1 a = a Eq1cong : �� {f g : Set -> Set} a ->
Eq1 f g -> Eq1 (f a) (g a)
Eq1cong a refleq1 = refleq1 Eq1sym : �� {A : Set1} { x y : A } -> Eq1
x y -> Eq1 y x
Eq1sym refleq1 = refleq1 Eq1trans : �� {A : Set1} { x y z : A } ->
Eq1 x y -> Eq1 y z -> Eq1 x z
Eq1trans refleq1 refleq1 = refleq1 data I : (Set -> Set) -> Set
where
Iinj : �� { x y : Set -> Set } -> Eq1
(I x) (I y) -> Eq1 x y
Iinj refleq1 = refleq1 data invimageI (a : Set) : Set1
where
invelmtI : forall x -> (Eq1 (I x) a) -> invimageI a J : Set -> (Set -> Set)
J a with exmid (invimageI a) J a | inl (invelmtI x y) = x J a | inr b = �� x �� Empty data invimageJ (x : Set -> Set) : Set1
where
invelmtJ : forall a -> (Eq1 (J a) x) -> invimageJ x IJIeqI : �� x -> Eq1 (I (J (I x))) (I
x)
IJIeqI x with exmid (invimageI (I x)) IJIeqI x | inl (invelmtI x' y) = y IJIeqI x | inr b with b (invelmtI x refleq1) IJIeqI x | inr b | () J_srj : �� (x : Set -> Set) ->
invimageJ x
J_srj x = invelmtJ (I x) (Iinj (IJIeqI x)) cantor : Set -> Set
cantor a with exmid (Eq1 (J a a) Empty) cantor a | inl a' = One cantor a | inr b = Empty OneNeqEmpty : Eq1 One Empty ->
Empty
OneNeqEmpty p = cast p one cantorone : �� a -> Eq1 (J a a) Empty
-> Eq1 (cantor a) One
cantorone a p with exmid (Eq1 (J a a) Empty) cantorone a p | inl a' = refleq1 cantorone a p | inr b with b p cantorone a p | inr b | () cantorempty : �� a -> (Eq1 (J a a) Empty
-> Empty) -> Eq1 (cantor a) Empty
cantorempty a p with exmid (Eq1 (J a a) Empty) cantorempty a p | inl a' with p a' cantorempty a p | inl a' | () cantorempty a p | inr b = refleq1 cantorcase : �� a -> Eq1 cantor (J a)
-> Empty
cantorcase a pf with exmid (Eq1 (J a a) Empty) cantorcase a pf | inl a' = OneNeqEmpty (Eq1trans (Eq1trans (Eq1sym (cantorone a a')) (Eq1cong a pf)) a') cantorcase a pf | inr b = b (Eq1trans (Eq1sym (Eq1cong a pf)) (cantorempty a b)) absurd : Empty
absurd with (J_srj cantor) absurd | invelmtJ a y = cantorcase a (Eq1sym y) =====================================
- [Coq-Club] Agda with the excluded middle is inconsistent ?, Chung Kil Hur
- [Coq-Club] Re: [Agda] Agda with the excluded middle is inconsistent ?, Dan Doel
- Re: [Coq-Club] Agda with the excluded middle is inconsistent ?,
roconnor
Chung Kil Hur
- Re: [Coq-Club] Agda with the excluded middle is inconsistent ?, roconnor
- Message not available
Chung Kil Hur
Andreas Abel
- [Coq-Club] Re: [Agda] Agda with the excluded middle is inconsistent ?, Thorsten Altenkirch
Andreas Abel
Chung Kil Hur
Chung Kil Hur
