- To: Chung Kil Hur <ckh25 AT cam.ac.uk>
- Cc: Agda mailing list <agda AT lists.chalmers.se>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Agda with the excluded middle is inconsistent ?
- Date: Fri, 8 Jan 2010 16:36:22 -0500 (EST)
On Fri, 8 Jan 2010, Chung Kil Hur wrote:
But, in this proof, we need to notice that we use "False : Prop" rather than
"Empty_set : Set".
If you change "False" to "Empty_set", then the type of R cannot be "Set -> Set", rather it
should "Set -> Type".
The reason why R is typable as Set -> Set is due to the impredicativity of Prop,
because R is typepable as Set -> Prop, which is
coercible to Set -> Set.
Ah, I didn't realize that Set was coercable to Prop otherwise I wouldn't have done my Type1 nonsense.
This proof does not need any axiom, but just the impredicativity of Prop.
So, this idea does not aplly to Agda because it does not have any
impredicative set like Prop.
So, I applied cantor's diagonalization assuming the law of excluded middle.
I think the presence of Prop is one of the fancy features of Coq as a proof
assistant (at least to me).
So, the injectivity seems unatural to me in this view point.
To be honest, the impredicativity of Prop in Coq worries me just a little <http://r6.ca/blog/20091101T231201Z.html>
"Coq’s impredicative in Prop seems innocent because no information is allowed to flow from the Prop universe to the Set universe; however Prop values can witness termination of functions in Set. Perhaps there is an inconsistency arising from the impredicativity of Prop that “proves” the termination of some non-terminating function.
But worries about impredicativity is another story.
Thanks repeating the info on the Agda list for me.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] Agda with the excluded middle is inconsistent ?, Chung Kil Hur
- [Coq-Club] Re: [Agda] Agda with the excluded middle is inconsistent ?, Dan Doel
- Re: [Coq-Club] Agda with the excluded middle is inconsistent ?,
roconnor
Chung Kil Hur
- Re: [Coq-Club] Agda with the excluded middle is inconsistent ?, roconnor
- Message not available
Chung Kil Hur
Andreas Abel
- [Coq-Club] Re: [Agda] Agda with the excluded middle is inconsistent ?, Thorsten Altenkirch
Andreas Abel
Chung Kil Hur
Chung Kil Hur
