- To: Flávio Leonardo Cavalcanti de Moura <flaviomoura AT unb.br>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] matching evaluation
- Date: Fri, 08 Jan 2010 08:55:06 -0500
Flávio Leonardo Cavalcanti de Moura wrote:
I defined the following recursive function:
Fixpoint prod_in (n m:nat) {struct m} := ....
"Eval compute in (prod_in 0 1)" returns 0, but if I declare a variable m
of type nat
"Eval compute in (prod_in 0 m)" doesn't evaluate to 0.
As you guessed, the problem has to do with the fact that the 2nd argument is the recursive one. Coq only beta-reduces [fix] expressions when they are applied to recursive arguments with known top-level structure. It's actually a really good thing that this restriction is in place; otherwise, [fix] beta reduction could be applied in infinite descent, leading the type-checker to diverge (and possibly making the definitional equality undecidable)!
- [Coq-Club] matching evaluation, Flávio Leonardo Cavalcanti de Moura
- Re: [Coq-Club] matching evaluation, Adam Chlipala
- Re: [Coq-Club] matching evaluation, Matthew Brecknell
